Oil cap breather
Old Mar 6, 2009 | 08:23 AM
bucwheat's Avatar
bucwheat
Default Oil cap breather
Hey guys,happy Friday,I have a question, I saw one of those small breather elements at Advance yesterday and would like to mount one on my oil cap ,has anyone here done it? I love the look.
Old Mar 6, 2009 | 09:11 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
I haven't seen that yet?
Old Mar 6, 2009 | 09:16 AM
bucwheat's Avatar
bucwheat
Somebody the other day had pic's of their engine bay and had one,it looked pretty cool and matched his open air breather element colors.
Old Mar 6, 2009 | 01:28 PM
bucwheat's Avatar
bucwheat
Found a K&N unit on flea bay for $55 seems kind of high,the washable filter at Advance was only $20.
Old Mar 6, 2009 | 04:31 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Unless your car is modded and setup for this, I would not put one of those on your car. My tuner intalled one on mine because they re-worked or removed the PCV system when they installed my H/C and FAST 90/90 setup and the breather cap allows the pressure to equalize in the crank case.
I cannot say for certain, but putting one of these on your car with the PCV system stil lin place might trigger a MIL. I am sure others will chime in.
Old Mar 6, 2009 | 04:50 PM
bucwheat's Avatar
bucwheat
You know I was wondering about that but several vendors sell them and it must be ok to install one ,I remember growing up that all cars had them.I'll check into it further,thanks.
Old Mar 6, 2009 | 04:51 PM
csexton's Avatar
csexton
Here's one for you
http://www.eastcoastsupercharging.co..._breather.html
Chuck
Old Mar 6, 2009 | 06:02 PM
Russ K's Avatar
Russ K
Installing a breather cap will cause lean fuel trims unless the PCM is tuned.
Russ Kemp
Old Mar 6, 2009 | 06:06 PM
hotwheels57's Avatar
hotwheels57
Vendors sell lots of things that are not necessarily good/legal/justified for a street car.
I think the people who use them most are those with superchargers. The rest just like the looks of them. They like form over function.
And I believe it defeats the purpose of closed PCV system. Depending on how hard you drive your car, condition of the internals, etc, you may find yourself cleaning "blow by" off the engine bay.
If you like it just for the looks, buy one and glue it on to the top of your oil fill cap. No one will know but you...
To Oil cap breather
