Cut the shroud method?
Old Mar 6, 2009 | 05:51 PM
vettegator005's Avatar
vettegator005
Default Cut the shroud method?
I did a search but couldnt find it. I just need a link to the DIY for the oil sender fix where you just cut a hole in the shroud so you can reach the unit.
Old Mar 6, 2009 | 06:09 PM
hotwheels57's Avatar
hotwheels57
You might check the stickie at the top of the C5 Tech forum...
Old Mar 6, 2009 | 06:11 PM
99silvercoupe's Avatar
99silvercoupe
Default shroud
dont cut it, buy a decent brass sensor from napa, not the cheepo aluminum from autozone and the like, and do it right, wont take you more than an hour.
Old Mar 6, 2009 | 06:14 PM
vetter79's Avatar
vetter79
http://forums.corvetteforum.com/c5-t...-relocate.html
Go to the above.
To Cut the shroud method?
