From: "This is not a psychotic episode, but a cleansing moment of clarity."
I'm not trying to be a tool, just trying to help. Isn't this something that just about any Chevrolet parts counter could answer for you by looking it up in their parts catalog?
I assume by headlight brackets that you mean the stamped angular piece that holds the headlight assembly to the side of the frame itself.
It helps support the front of the fender also.
The wrench head size is 10 mm. They screw into a captive nut that snaps into the side of the frame rail. The nut is encased in a thin sheet metal cage that is held in the side of the frame rail. I had one that was stripped out.
The screw size is M6 x 1.25, I believe, but if you don't have the captive nuts you will have to get them from the dealer or aftermarket bolting supplier.
