Starting Issue
Old Mar 8, 2009 | 05:53 PM
s-driver's Avatar
s-driver
1st Gear
Default Starting Issue
A neighbor has an '04 C5 vert and the car will not start. Turn the key and I hear a "clicking" noise similar to what a bad starter sounds like. Sound is coming from under the right (pass side) side of the engine. There is no dome light or under hood light working and he states no parking lights either.
Apparently the car was started every month prior to this and now this is happening. Would this be some sort of a security "lock out" initiated by accident or simply a bad starter/battery issue? Car is not on a battery/trickle charger and never has been. 42k on the odo....auto trans. That ambiant light from the rear view mirror is working as well dash lights and gauges do sweep when you attempt to start. Clock is lit and temp display on temp contols function.
Any ideas as I'm not too familiar with GM electronics...
Thanks..
Old Mar 8, 2009 | 06:04 PM
realvc's Avatar
realvc
Usually the simpliest and most basic things that fail are the battery connections, battery as in low charge and then starter solenoid and starter. So be sure the battery connections are good and the battery is fully charged. It is easy to overlook the simple and most basic of problems. I have seen cars towed in that just needed a battery cable tightened.
Hope this helps.
Old Mar 8, 2009 | 06:06 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Hope this helps.
Gotta check that stuff first!
Old Mar 8, 2009 | 06:21 PM
Phanni's Avatar
Phanni
Have you attempted a jump? It sounds like a dead battery to me.
Old Mar 8, 2009 | 07:27 PM
dobewillie's Avatar
dobewillie
check connections and recharge if that don't help you just may need a new battery good luck
Old Mar 8, 2009 | 07:31 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 9, 2009 | 10:52 AM
jovette's Avatar
jovette
Rather than jump start, much better / safer to put battery on a charger and then try to start, after fully charging battery. Personally, I'll never jump start my C5, too much chance for creating other problems.
Old Mar 9, 2009 | 10:55 AM
Vega$Vette's Avatar
Vega$Vette
battery
Old Mar 9, 2009 | 10:59 AM
Vega$Vette's Avatar
Vega$Vette
Like what? That makes NO sense. When you jump all you are doing is adding another battery with a parallel connection.
Just don't touch positive to ground. It's really very simple and safe to do.
Old Mar 9, 2009 | 11:10 AM
Vega$Vette's Avatar
Vega$Vette
Originally Posted by 8VETTE7
Battery is dead. Bet it's the original. Check the battery caoonections to make sure they are clean, bright and tight.
DO NOT JUMP IT
Again this makes NO sense. What's the difference between jumping and installing a fully charged new battery?
Old Mar 9, 2009 | 11:22 AM
Vega$Vette's Avatar
Vega$Vette
My reason for not jumping the battery is the battery is obviously dead. Jumping it he might well get the car running. But it will take many many hours of driving to fully charge the battery off the alternator. If the battery is bad and you shut it down someplace not near home you are likely to have the car not start and then either need to find someone to jump it again or need it towed. My approach is find out what's going on near home and NOT invite unnecessary complications. You are welcome to your opinion just as I am for mine.
I agree with your logic re: being close to home so it doesn't go dead and leave you up the creek.
My issue is with people who say you will do damage by jumping.
Old Mar 9, 2009 | 11:32 AM
o2z51's Avatar
o2z51
Jeez the 4f4in battery is dead, go to autozone get a nice stock ac delco new batt for 100 re install, enjoy for another 4yrs
To Starting Issue
