Catch Can?
Old Mar 16, 2009 | 02:58 PM
justin_heat05's Avatar
justin_heat05
Default Catch Can?
I'm new to the catch can. What is it for? Where does it go? Is it too late at 111,000 miles????
Old Mar 16, 2009 | 03:03 PM
Dave68's Avatar
Dave68
Here's a primer for you:
http://www.conceptualpolymer.com/PCV...oval%20102.pdf
Is it an exact science? No, not by a long shot, but I am working on coming up with something that is engineered, rather than thrown together.
Old Mar 16, 2009 | 03:11 PM
justin_heat05
I can't open it, my work computer doesn't have the software........
Old Mar 16, 2009 | 03:28 PM
slothy's Avatar
slothy
www.adobe.com - acrobat reader
Old Mar 16, 2009 | 03:34 PM
justin_heat05
thanks, didn't know it was free.......lol
can someone just sum it all up, thats a lot to read........
Old Mar 16, 2009 | 03:59 PM
hotwheels57's Avatar
hotwheels57
You don't need any software to search or search this forum (in the red banner) in C5 Tech.
Use keywords "oil catch can" and plan to do lots of reading.
It's purpose is as simple as the keywords...catches oil in a container before it can enter the intake system.
And it's never "to late"...
Dave68's Avatar
Dave68
To answer your previous question - no, it is not too late, since oil does not evaporate - it accumulates/pools in your intake. Over time, your compression ratio will increase as the volume of space abobe each piston is reduced when carbon builds up. And unless you increase the octane of the fuel you use, your ECU will "hear" the pinging and reduce engine power.
I still think you should read the article............
Old Mar 16, 2009 | 04:03 PM
hotwheels57
Read this, complete with images...
http://www.eliteengineeringusa.com/Catch_Can.html
Old Mar 16, 2009 | 05:12 PM
Bills03Coupe's Avatar
Bills03Coupe
I have the Elite Catch can in my 03'. It does work. It "catches" oil that otherwise would be in my intake!
Old Mar 16, 2009 | 08:07 PM
dobewillie's Avatar
dobewillie
they do work call Chip@CCA he can hook you up
Old Mar 18, 2009 | 12:00 AM
Tyke's Avatar
Tyke
No mean to HIJACK, but is there anything you can do to I guess 'clean' the intake if a car has not had a catch can on 100K miles?? What sort of thing scan u do to remove this pooled up oil?
Old Mar 18, 2009 | 09:06 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
The easy way is to take off your Throttle Body and just reach in and mop up the oil.
The best way is to remove your manifold and clean it...
Peace
Chip
__________________
..................Click for
Old Mar 18, 2009 | 09:29 AM
GRUNIE's Avatar
GRUNIE
I was amazed with the amount of oil my can had in it after only couple thousand miles. They work
Old Mar 19, 2009 | 06:46 AM
vetter79's Avatar
vetter79
Works great - You'd be surprised the amount of Oil residue it catches!
Old Mar 19, 2009 | 06:56 AM
Tigershark3's Avatar
Tigershark3
I've put one on and I'm glad I did. First time I checked it after several months there was probably an inch of oil in the bottom.
Old Mar 19, 2009 | 08:22 AM
Plus they sell an excellent product.
Old Mar 19, 2009 | 12:45 PM
justin_heat05
thanks guys, I wonder why gm didn't think of this?
To Catch Can?
Old Mar 19, 2009 | 02:55 PM
Dave68's Avatar
Dave68
The backlash from consumers being told they'd have to empty a can every few months because of an imperfect engine design would be swift and brutal. Many big rigs and busses use air/oil separators, but the collected fluids are either routed back to the oil pan or are contained in an isolated tank. Filter experts agree that you should never expose outgoing air to collected liquids, so If GM included a filter, it would not look like a typical catch can, which allows the outgoing air to entrain oil that is sloshing around underneath it. It would probably look more like a miniature version of what the big rigs use.
Old Mar 19, 2009 | 03:14 PM
hotwheels57
They didn't want to interfere with the after market...
Old Mar 19, 2009 | 05:19 PM
heavymetals's Avatar
heavymetals
I had to put two on because my LS6 (in my V) has outlets on both valve covers.
The driver side is the one that seems to "catch" the most oil.
