Fuel Door issue
Old Mar 19, 2009 | 10:28 AM
minitech's Avatar
minitech
Default Fuel Door issue
I had my rear interior out to adjust the soundproofing and saw the fuel release cord. I knew it was there but never needed to use it as the door switch works fine. BUT I pulled it just to see if it worked. It did work but now the door doesn't stay closed and the electric switch doesn't always open it.
From what I can tell the locking pin is binding some and not letting the spring loaded latch move freely.
Anyone had this happen? What to do?
Old Mar 19, 2009 | 11:02 AM
CODE4LS1's Avatar
CODE4LS1
Try lubricating the locking pin with some silicon spray or penetrant. Worked fine for me.
Old Mar 19, 2009 | 11:46 PM
minitech's Avatar
minitech
One drop of heavy oil and working the pin did the job. Thanks!
Old Mar 20, 2009 | 12:35 AM
CODE4LS1's Avatar
CODE4LS1
That'll be $49.95, Paypal is code4ls1@aol.com
J/K.
You're welcome.
Old Mar 20, 2009 | 02:22 AM
DeeGee's Avatar
DeeGee
A $0.01c fix. Priceless
Old Mar 20, 2009 | 07:22 AM
minitech's Avatar
minitech
J/K.
You're welcome.
What, only a half hour billed out!
Old Mar 20, 2009 | 08:43 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
J/K.
You're welcome.
Old Mar 20, 2009 | 08:46 AM
bucwheat's Avatar
bucwheat
To Fuel Door issue
