Sunvisor Vanity Light Wiring
Old Mar 19, 2009 | 03:19 PM
mtwalet's Avatar
mtwalet
Default Sunvisor Vanity Light Wiring
I have a Y2K vert that I am going to install a Homelink opener in. Before I remove the sunvisor, I'd like to get all my ducks in order so I can make the installation quick and neat.
My Homelink has an Orange wire and a Black wire. I hooked the Orange to the positive side of a battery and the Black to the negative side of the battery. I programmed the opener in a matter of minutes since it had power. So Orange (+) and Black (-).
As I look at the Y2K service manual (vol 3, page 8-58) vanity mirror electrical diagram, it says the wires are Orange (+) and Black (-). If I can trust the manual and these colors are correct, I have no problems. But I have seen many conversion pictures on this site and the other DC site as well. The wiring colors I see on the visors are RED and White.
Does anyone know or can tell me what colors the wiring is? If the wires are Red and White, which wire color is the HOT one and/or which color is the ground wire?
I don't have a tester, so in lieu of the trial, error, and fuse blowing I would like to know what anyone else has experienced. I don't think GM would have changed the wiring colors on any of the C5 models, but I could be wrong.
Thanks,
Doug
Old Mar 19, 2009 | 11:13 PM
mtwalet's Avatar
mtwalet
Old Mar 19, 2009 | 11:41 PM
nextime's Avatar
nextime
A simple volt meter or test light will show the power wire, that is how I hot mine after I did the same install you are doing.
Old Mar 20, 2009 | 02:26 AM
DeeGee's Avatar
DeeGee
As you say the wiring diagram shows orange as hot and obviously black as ground. But you're also correct that when you open up the mirror you'll see red & white. Presumably the hot wire on the circuit going through the vanity mirror bulb has red to one side and white out. Maybe a qualified auto electrician can explain why?
I'd say you're OK if you're hooked up to the orange.
Old Mar 20, 2009 | 03:55 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
here ya go:
http://www.digitalcorvettes.com/foru...light=homelink
that's what I used to install my homelink in my visor... worked like a champ.
black from your homelink spliced into the red in the visor.
orange from your homelink spliced into the white wire in the visor.
Old Mar 20, 2009 | 08:45 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Originally Posted by still-asleep
here ya go:
Old Mar 20, 2009 | 02:45 PM
mtwalet's Avatar
mtwalet
here ya go:
By this diagram the red appears to be the ground and white hot. I will give this a shot. It does look logical.
Thanks all
Old Mar 20, 2009 | 03:01 PM
Vega$Vette's Avatar
Vega$Vette
Thanks all
That's right. It is opposite of what you would think.
You can also hit the button to make sure it works right before you pop the visor back in.
Old Mar 20, 2009 | 06:16 PM
Jake the Snake's Avatar
Jake the Snake
I believe white is positive, red ground, but please check. I put mine together using the above provided diagram (car was in storage 1500 miles away so I couldn't verify) Yep it was wired backassward and didn't work. Fortunately, the sewing only cost $4.00 (each time). Still a great DIY mod.
Old Mar 20, 2009 | 07:07 PM
nextime's Avatar
nextime
Nothing like trying a test light to be positive?
Old Mar 20, 2009 | 08:10 PM
JropTop's Avatar
JropTop
yes,red isw ground,white is hot,i did mine a few weeks ago and what a stock clean look instead of having that remote clipped to the visor!Bought a homelink on ebay for $25 and did it myself,where as there are vendors who are selling the visor and homelink for $195! good luck!
Old Mar 20, 2009 | 08:49 PM
Vega$Vette's Avatar
Vega$Vette
I did my Vette a couple years ago and just did my 55 Chevy.
Old Mar 21, 2009 | 02:07 AM
DeeGee's Avatar
DeeGee
Can any auto electricians on the Forum explain why they didnt stick with orange and black as per the wiring diagram?
Old Mar 21, 2009 | 12:04 PM
nextime's Avatar
nextime
They probably got a good deal on the other colored wire, happens a lot.
Old Mar 24, 2009 | 04:20 PM
mtwalet's Avatar
mtwalet
here ya go:
As they say in the South, "you all ain't gonna believe this s**t!
I installed my Homelink as per photos and as per above.
When I hooked up the wires according to all of the pictures (link) and the way it is described it, the Homelink DID NOT work!
I pulled the connector down from the visor hole and saw an orange wire and a black wire as described in the manual. The visor vanity side of the plug was wired with red and white wires. When I lined up the plug connections, I saw the orange wire (hot) from the harness connected to the red side of the visor vanity plug. I hooked the orange Homelink wire to the red visor wire and the black Homelink wire to the white visor wire. ALL WORKED including the vanity lights!
Operation a success, but I can see how this could get confusing if you are 'winging' it. Bottom line in this lesson is the car harness wiring to the vanity visor plug is Orange (+) and Black (-). Not all Homelinks are wire colored the same. I didn't work for me until I reversed the wires. I even took the Homelink and double checked it's operation by hooking it directly to the battery and it function the door opener. Now I can't understand why you all have a different connection in your visors making your Homelink operational.
Tomorrow I'll get the visor sewed up and back in the car.
Thanks again to all!
Old Mar 24, 2009 | 05:22 PM
nextime's Avatar
nextime
I posted on another topic about this a long time ago what wire was hot on the homelink, I took it apart to see what one was.
P.S. A homelink will not operate hooked up to a battery charger, it must be a battery to power it. I have tried it and I know this wont work.
To Sunvisor Vanity Light Wiring
