Question ?
Old Mar 19, 2009 | 08:45 PM
thematrix17's Avatar
thematrix17
Default Question? headlights come up in the running position??
HI guys..I just bought a 2000 frc..and I notice the headlights come up when I put the running lights on..On my c4 just the running lights would come on ...Is there any way to keep them down while you have the running lights and fogs on? thanks
Old Mar 19, 2009 | 08:59 PM
pinballfanatic's Avatar
pinballfanatic
If the lights are coming up with just the driving lights on then you probably need to repplace your nylon gear or gears on your headlight motor(s). When they get stripped the lights do funny things. I replaced mine with brass gears...no more problems!
Old Mar 19, 2009 | 09:35 PM
thematrix17
ok..but if just the running lights are on, should there even be any power going to the motors ?
Old Mar 19, 2009 | 09:46 PM
3GenVettes's Avatar
3GenVettes
If I turn the stalk only to the parking lights and do not go past that position the headlight doors stay closed. With the parking lights on, I can also turn the fog lights on and the headlight doors still remain closed. However, if you turn the stalk past the parking light position the doors raise and they do not close again until you turn the lights completely off.
You did not mention whether you have the twilight sentinel feature or not. If so, that must be off, if you want the headlight doors closed.
Old Mar 19, 2009 | 10:15 PM
thematrix17
I am not sure if I have that feature..I will check that out tho.. thanks
Old Mar 19, 2009 | 10:25 PM
redrckt97's Avatar
redrckt97
[QUOTE=3GenVettes;1569367553]If I turn the stalk only to the parking lights and do not go past that position the headlight doors stay closed. With the parking lights on, I can also turn the fog lights on and the headlight doors still remain closed. However, if you turn the stalk past the parking light position the doors raise and they do not close again until you turn the lights completely off.
this is how they are supposed to work - go to headlights and then back to parking lights and the doors Should stay open - among other things, this allows you to get to the bulbs when needed.
Old Mar 19, 2009 | 10:30 PM
thematrix17
I understand that, but they come up in the running position, before I switch to headlight..so the only option is up.
Old Mar 19, 2009 | 10:31 PM
AIKMAN8's Avatar
AIKMAN8
Don't know how to fix it but you definately have a problem. I saw a thread a few days ago regarding this and I think it had a fix posted. Good luck finding it!
Old Mar 19, 2009 | 11:03 PM
thematrix17
Thanks Aikman8...I will try to find that thread
Old Mar 19, 2009 | 11:18 PM
AIKMAN8's Avatar
AIKMAN8
Good luck, the answer is out there!!!
Old Mar 20, 2009 | 12:23 AM
thematrix17
wow I can't find that thread Aikman8...lol..Any one have any suggestions? thanks
Old Mar 20, 2009 | 12:49 AM
Harley2Vette's Avatar
Harley2Vette
try looking at this. http://forums.corvetteforum.com/c5-g...opping-up.html
Old Mar 20, 2009 | 01:10 AM
marshterry's Avatar
marshterry
Read post #2 here:
http://forums.corvetteforum.com/c5-t...with-pics.html
Go to the top of this thread for extra info on this fix:
http://forums.corvetteforum.com/c5-g...post1562077756
Quote;
The headlights cycle open and closed when they shouldn't. For example, when arming or disarming the alarm or just turning on the fog lights or parking lights, the headlights will cycle or go up but not on. This is actually 100% related to the stripped gear. In every case where I have heard of people complaining about the lights cycling or coming up when they shouldn't, they also have the problem of the stripped gear as mentioned above.
Order from:
RodneyDickman.com
OR
http://www.bfranker.badz28.com/headl...htgearfailures
I've ordered twice from Rodney and great service both times.
Old Mar 23, 2009 | 01:55 AM
marshterry's Avatar
marshterry
Were you able to get it fixed?
To Question ?
