Factory BOSE headunit question!!
Old Mar 22, 2009 | 07:52 PM
crAzy's Avatar
crAzy
Default Factory BOSE headunit question!!
Ok i have a buyer for my stock bose headunit out of my 2003 Z06. Well the buyer came up with a question asking me if i knew the lock code for the headunit? I never knew it had a lock code as i never had a owners manual with the car. Just bought it about a month and half ago. What i was wondering is would he need a code when i sell him my headunit? Im cluesss about this situation as i never had this happen before. The headnit does say theftlock on it. I just want to make sure if this can be bypassed or do i have to plug it back up and have the code reset, etc?
Please let me know and thanks for looking...
Randy
Old Mar 22, 2009 | 08:00 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I could be wrong, but unless the lock code was set by you or a PO if someone owned the car before you, it will be fine. If your HU had a red flashing LED going when the ignition was off, then the code was set and someone else will need to walk you through the steps to disable it. I think it's covered in the manual if I remember correctly.
Old Mar 22, 2009 | 08:31 PM
Bill W's Avatar
Bill W
I replaced my stock unit with another used stock unit when the CD quit working. No issues. Fired right up.
Old Mar 22, 2009 | 09:21 PM
crAzy's Avatar
crAzy
It worked... Thanks guys.. He was very happy that it worked...
Old Mar 23, 2009 | 01:56 AM
KRISCO's Avatar
KRISCO
The theftlock must not have ever been set
Old Mar 23, 2009 | 02:06 AM
DeeGee's Avatar
DeeGee
Theres a procedure for finding out the code from a 1-800 number. Its in the Tech Tips database but there are problems accessing that at present. I'll try to find it from another source.
Here you go:
UNLOCK RADIO
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere). Procedure: 01. Turn the ignition ON (The radio displays LOC) 02. Hold down the Radio Presets 2 and 3 buttons for six seconds 03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step. 04. Press the AM/FM button 05. The radio display changes to another three-digit number. Write this number to the right of the first one. 06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05 07. Call 1 800 537 5140 08. Press 1 then # (pound). You’ll hear “Invalid Code, try again” 09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start) 10. Enter the number from STEP 6 then * (star) 11. Listen to the four-digit number and write it down. It will be repeated twice 12. Turn the ignition ON (The radio displays LOC) 13. Use the MN and HR buttons to enter the code from STEP 11 14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
To Factory BOSE headunit question!!
