H.I.D. Light kit install
Old Mar 20, 2009 | 11:08 AM
adam954rr's Avatar
adam954rr
Default How do I install an H.I.D. Light kit
does anyone know how to install a HID light kit?
Old Mar 20, 2009 | 11:26 AM
adam954rr's Avatar
adam954rr
hello?
Old Mar 20, 2009 | 11:37 AM
Polar Jet's Avatar
Polar Jet
Try doing a search using the "search" feature. I'm sure you will find lots of useful information.
Old Mar 20, 2009 | 12:14 PM
77Stingray99's Avatar
77Stingray99
Its real simple depending on what kit you got. I just ordered one through JW motoring and it was as easy as installing a stock headlight bulb. What kit did you buy?
Old Mar 20, 2009 | 12:38 PM
TheDingo's Avatar
TheDingo
^ do you get the 9006 kit?
Old Mar 20, 2009 | 02:37 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Depends on what kit you bought and what lights you are swapping out. Swapping any are pretty straight forward. It is easier if you remove headlight surrounds & hood stops. The wiring will be different depending on the kit you purchased.
Old Mar 20, 2009 | 02:45 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
I just installed a set last night, didn't need to remove the downstops, though I did remove the black shroud and the painted headlight cover. Had plenty of headache finding somewhere to mount the ballasts since I was going with double-sided adhesive tape / foam, and will likely swap that out to have it bolted down soon.
Old Mar 20, 2009 | 02:59 PM
UncleFodder's Avatar
UncleFodder
Try this:
http://forums.corvetteforum.com/c5-t...ll-lights.html
Old Mar 20, 2009 | 03:57 PM
adam954rr's Avatar
adam954rr
Yeah, the 9006 kit
To H.I.D. Light kit install
