Antenna question/tire sensor question
Old Mar 20, 2009 | 01:21 PM
frankb's Avatar
frankb
Default Antenna question/tire sensor question
I changed my mast on the antenna after reading in the search area on the problem. I though that I did what was said but have the mast sticking up about 3". If I cut off 3'' of the white plastic teeth would that work? I had removed the motor and tryed to do what was said but screwed something up.
I had a low tire on the dash that said lower RR tire. I checked the right side but it was the driver side that was low. Can someone explain how this is posible. Do the rims make it left and right. Thanks for any information. Frank
Old Mar 20, 2009 | 01:33 PM
Corvette Don's Avatar
Corvette Don
For the tire sensor issureyou need a simple reprogam to the correct spots. That will fix that.
Old Mar 20, 2009 | 01:42 PM
DeeGee's Avatar
DeeGee
Heres the fix for the antenna. If you followed the procedure and it still sits up proud, start over.
How To Replace a Defective Telescopic Antenna
Now this is a simple mod and the OEM assembly with motor is $130+. You'll know you have the problem because the antenna won't fully retract
Parts:
Adjustable wrench
GM OEM Power Antenna Replacement ($13 E Bay).
Make sure the antenna is fully retracted and that the radio is off
Remove the antenna mounting nut located on the base of the mast on the outside of the car. If the mast is bent it may be necessary to cut off the old mast). If you can't all of the plastic cable out as one piece, (sometimes the plastic gets really hard and breaks into pieces then falls down into the motor), you can just pull the motor after you have pulled the mast out and get all of the pieces out. To do that you'll need to take out the outer right turn signal housing.
Turn on the radio and pull out the old mast and serrated cable completely out of the antenna motor. (Note which way the serrations on the cable are facing)
Feed the serrated cable of the new mast into the antenna hole and stop when resistance is felt. (about 12”). Make sure the cable is fed in with the teeth the same way the old cable came out.
Turn the radio off to lower the antenna until the serrated cable catches.. You may have to cycle the antenna a few times until the cable catches the gear mechanism and retracts into the antenna motor.
Replace and tighten the antenna nut into the mast base.
Turn on and make sure that the mast fully extends without binding. Clean the surface of the antenna to remove any adhesive etc.
10 minute job.
If you encounter a stuck mast here’s advice from the mast vendor:
You see the new "Retaining Sleeve" (silver, 2 inches or so, with slots) on the shaft of the new antenna mast, the original one is most likely a little corroded/frozen into the shaft of your antenna No problem : You are in need of what I refer to as the "snap and tap" technique of mast removal
Turn radio on and let cycle to as much extension as is currently possible
Take hold of the thickest metal mast section (closest to fender) with you thumb and forefinger about 2-3 inches above the top of the antenna shaft hole
Push the thickest mast section into the shaft (as much as it will go within that 2-3 inches)
Hold tightly with thumb and forefinger and Snap your Wrist upward.....you will here the mast bottom "tap" the bottom of the frozen in place retaining sleeve (what this is all about) Repeat this over and over again In-Snap-Tap-Repeat Short Firm Bursts of Energy Focusing the energy blow to the point of the tap This will free the retaining sleeve little by little till it comes out completely
Old Mar 21, 2009 | 09:00 AM
frankb's Avatar
frankb
Thanks for the help guys. lets see if I can get this right this time.
Old Mar 21, 2009 | 05:49 PM
Jacks02's Avatar
Jacks02
The above writeup is good information. To answer your question: DO NOT cut off any of the white nylon strip. Turn your radio on and off a few times, and the mast should retract fully. If it doesn't, you have a piece of the old (hard) nylon strip inside the motor assembly. Pull the motor, unscrew the "round" section on the side, remove the broken-off old piece, lightly lubricate the cavity with white grease, re-assemble and install. Be sure to also put a light coat of white grease on the new antenna mast nylon part before re-installing as decribed above. Simple fix -- I did it a couple of weeks ago.
Old Mar 21, 2009 | 07:35 PM
dobewillie's Avatar
dobewillie
great write up DeeGee thanks
Old Mar 22, 2009 | 03:31 AM
DeeGee's Avatar
DeeGee
No trouble
Mine's just starting to sit proud again. I may take my own advice soon
Old Apr 10, 2009 | 06:02 PM
blckstn's Avatar
blckstn
6th Gear
Originally Posted by Jacks02
Pull the motor, unscrew the "round" section on the side, remove the broken-off old piece, .
I have pulled the motor and find it quite impossible to get inside the gear assembly to the broken piece. Can you explain this with more detail?
Old Apr 11, 2009 | 12:07 PM
blckstn's Avatar
blckstn
6th Gear
I drilled out the plastic rivets holding the assembly and retrieved the broken piece and reassembled the case using some small screws. It seems to work fine.
To Antenna question/tire sensor question
