Modern radio C5 replacement?
#101
There is an interface wire harness that you can use for installing an aftermarket head unit to retain the Bose woofers.
The stock radio is an odd size (1.5 din). You can install a single din with a kit to fill the void or you can get a new radio bezel with a larger opening for a double din touch screen head unit.
You can contact Denis at Double D Mods for kits and advice.
#103
Might I suggest to anyone postponing doing the double din mod due to modding the console issues. I purchased a stock console on e-bay and sent Dennis the console out of my car. Once it was returned and the new head unit was installed, I sold the temporary unit back on e-bay and recovered my investment without having to lay up my car. Plus, I have to say that having a modern radio with all the new tech features is absolutely worth the investment. Especially having handsfree bluetooth, nav, and the back-up camera. Front camera will have to be done soon, I am the worst procrastinator.
#106
I also have an amp, separates for up front, RF for the rear, and a sub for the well. Do I need some sort of harness? Unfortunately after I bought all this stuff, I got cancer. Fast forward 3 years, I'm fine and want to finish my project. I have to install everything but the head unit. I ran rca cables to where the amp will be, and assume I will pull speaker wire to the others. Do I just disconnect the Bose fuse and does the amp come out with the speaker?
#107
After 4 replacement Kenwoods in one year, Excellon, top of their line, I'll never touch anything Kenwwod again!
#108
Just a heads up an option
Bill aka ET
AS far as the boot up screen I designed that myself in Photoshop turned it into a bit map, and uploaded it to the Head unit.. I made a couple different ones.
Sir, these look amazing. Great job!
Bill aka ET
