tire question
Old Mar 22, 2009 | 04:39 PM
petecnh320's Avatar
petecnh320
Default tire question
I just got a 2001 c5 , it is in need of new rubber all around ,
can someone point me in the right direction for new tires . the wheels are stock and i am not looking for a track tire all my driving will be on local roads , i see tirerack.com has a few options . i would just like some input as to what you guys are using .
thanks
pete
Old Mar 22, 2009 | 05:09 PM
army2000's Avatar
army2000
St. Jude Donor '11
www.tirerack.com
Old Mar 22, 2009 | 05:45 PM
pikerunner's Avatar
pikerunner
Try the Michelin Pilot Sport Run Flats. I have the All Season and they are wearing great and do not have much road noise as the Goodyear's.
Old Mar 22, 2009 | 05:53 PM
csc67's Avatar
csc67
I just put General Exclaim on my C5 - Have only had them on for 200 miles, but so far so good - Ranked # 4 out of 39 in survey and has 380 treadwear rating - $550.00 shipped from TireRack
Old Mar 22, 2009 | 05:57 PM
Hammer99's Avatar
Hammer99
Are you wanting runflats or non? Alot of guys are moving away from the runflats for various reasons. It is purely subjective...but two diff. catagories to look at. I'm sure alot of guys will chime in w/their opinions. There is also the question: what is your budget? If you are looking for a good inexpensive non runflat, look at the Sumitomo HRTZ III. Tire Rack: 245/45/17 $102.00 275/40/18 $139.00 Or if you can spend more, look at the Goodyear GS-D3 255/40/17 $207.00 285/35/18 $293.00 those are the biggest you can go on stock rim size.
Old Mar 22, 2009 | 06:26 PM
BigDave6's Avatar
BigDave6
I went with the Sumitomos just a couple of weeks ago - from Tire Rack. Compared to my old worn out runflats these things are awesome... you'll find a ton of tire debates if you look around here...
Old Mar 22, 2009 | 06:27 PM
petecnh320's Avatar
petecnh320
i was looking at something similar to a stock tire , i dont intend to drive it too hard , what are the advantages to a run flat , and are there any disadvantages to a non run flat . i also dont want to break the bank buying new rubber .
Old Mar 22, 2009 | 07:50 PM
Dave68's Avatar
Dave68
You need to ask yourself - How often have I had a blowout, such that I was left stranded? If you have never had this happen or it was so long ago that you can't remember the year, you'll be better off with non-runflats. Their superior ride is priceless, IMO and my experience is that most leaks are slow enough so that you can easily find any tire shop before the tire actually goes flat.
Now, let's talk about performance: Do you.....
-rarely take a corner fast enough to catch the attention of a police officer?
-never exceed 100 MPH?
-would shudder if a bunch of buddies asked to to join them on a road course like Virginia International Speedway?
If you answered yes to all of the above, an inexpensive set of tires like the General Exclaim, Avon Techs, or Sumitomos may be perfectly acceptable.
However, if you drive your C5 to its limits (occasionally or more often), then a top-tier tire like the Goodyear GSD3 (best all-around for the price and lasts longest), a BF Goodrich KD2 (a bit noisy, but very competant tire), or Michelin PS2 (does everything well, but priced for the wealthy buyer) tire is a much better solution.
Old Mar 22, 2009 | 07:54 PM
RonJ's Avatar
RonJ
GSD3
RonJ ...
Old Mar 22, 2009 | 08:17 PM
Hammer99's Avatar
Hammer99
Well put.
Old Mar 22, 2009 | 08:29 PM
CUlookin's Avatar
CUlookin
GSD3 here, had them on my stockers for a while now and love em, run Pirelli P-Zero's on the bling..
Old Mar 22, 2009 | 09:07 PM
If you want to stick with runflats, Firestone Firehawks or Michelin's are good choices. For non-runflats, Goodyear GS-D3 or Michelin Pilot Sports are fine tires.
Old Mar 23, 2009 | 11:27 AM
OUFAN76's Avatar
OUFAN76
I have about 2000 miles on a set of michelin pilot sport plus all season zp's (run flat). very pleased with them. I don't know how the run flats compare with the non-runflats in this same tire, but the difference between these and the goodyear run flats I took off is dramatic. So much so, that imo, the only factor I would consider between the two would be the price difference. Also, the tread wear rating is so high on these tires, it helps justify the higher price when compared to something that costs half but will only last half as long.
Old Mar 23, 2009 | 01:01 PM
Tonycpa's Avatar
Tonycpa
Michelin Pilot Sport 2s are rated #1 by customers who have driven a combined 8 million miles (you can find the survey results at Tire rack).
I have them on my C5 and there is nothing better for your intended use).
They would be $1,310 brand new for a set-of four on Tirerack or you could check out this deal...
http://forums.corvetteforum.com/c5-p...post1569284763
thanks
pete
Old Mar 23, 2009 | 01:34 PM
vetter79's Avatar
vetter79
Just put the above A/S run flats on mine- Love 'em!!
http://www.discounttiredirect.com/direct/home.do
$900.00 /4 shipped from the above site in stock C5 sizes.
Also new TPMS units with original Manuf. name instead of GM's name (made by same company and a lot cheaper)
http://www.revolutionsupply.com/(S(1...z))/index.aspx
Good luck
Old Mar 23, 2009 | 04:23 PM
c5vetteman99's Avatar
c5vetteman99
i bought my pilot sports a couple months ago. i love them. goodyear makes great tires, but these michelins make it feel like a completely different car. no road noise and turn on a dime.
Old Mar 23, 2009 | 06:09 PM
happa's Avatar
happa
I love my KDW 2's they ride very good and have a pretty good tread life. They are pretty sticky and drive good in the rain. Good Luck!
To tire question
Old Mar 26, 2009 | 03:50 PM
petecnh320's Avatar
petecnh320
A big thanks again to everyone , i ordered tires from tire rack yesterday around 2 pm est. I pulled into the drive way @ home and there were 4 new tires . Less than 24 hours and they are in my driveway , awsome !!!!
Old Mar 26, 2009 | 03:57 PM
petecnh320's Avatar
petecnh320
Forgot to ask , i am taking the tires to be mounted do i have to retrain the sensors , or anything i should know . Sorry for all the questions , i am a new owner to this car. All my others are pre 1969 muscle cars .
Old Mar 26, 2009 | 04:06 PM
Logansar's Avatar
Logansar
What he said!
