2002 Convertible
Old Mar 24, 2009 | 02:21 PM
mazevedo's Avatar
mazevedo
Navigator
Default 2002 Convertible
Hello,
We purchased our first Vette this past weekend and quite impressed with the car. However, my wife noticed that the sun visor mirror side (of course) has become unattached at the top or the mirror from the sun visor on both sides. Anyone have any experience with re-attaching vs. replacing both visors?
Old Mar 24, 2009 | 02:24 PM
dougbfresh's Avatar
dougbfresh
There is a write up in the Tech Tips but I think that section is currently messed up. It involves small zip ties to reattach, a new visor is about $100 online (MidAmerica and the like).
Old Mar 24, 2009 | 05:10 PM
DeeGee's Avatar
DeeGee
This is how I did it:
Refix Vanity Mirrors
Pull the mirror away from the housing gently. Stick a piece of 3M double sided tape along the inside edge of the top of the mirror between the two holes in the visor.
Thread a small zip tie through each hole from the back and outside of the hole, with the “head” of the tie located in the large rectangular recess. Pull the tail of the zip tie towards you and thread from inside to out through the hole in the locating pin. Push the tail through the head loosely at first.
Use needle nosed pliers (holding the tail) and a precision screwdriver (pushed against the head) to tighten the zip ties. Be very careful when pulling the ties tight not to pinch the lighting wires which run through the same hole. Once tight, snip the spare tail of the tie but carefully so as not to snip the electrical wires.
Push the mirror back into its housing and press firmly against the double sided tape.
Should be good as new.
Old Mar 24, 2009 | 05:14 PM
BlueDream's Avatar
BlueDream
Cool write-up with pics DeeGee!
And I hope you enjoy the new Vette Mazevedo!
Old Mar 24, 2009 | 05:53 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Welcome! Plenty of help here on the forum
Old Mar 24, 2009 | 07:03 PM
Jet-Jock's Avatar
Jet-Jock
GM's new sunshade will cost you $96.
Old Mar 24, 2009 | 07:07 PM
dobewillie's Avatar
dobewillie
good write up and post DeeGee
Old Mar 24, 2009 | 07:32 PM
widewheel's Avatar
widewheel
I used DeeGee's write up to fix my passanger side visor and have had no problems since.
Old Mar 24, 2009 | 11:30 PM
mazevedo's Avatar
mazevedo
Navigator
Thank you for the warm welcome and extreme detail with the sun visor repair! I will try this over the weekend.
I have also seen visor replacements on Ebay ~$100.00 for both sides and considering that too. Our 02 is a convertible only has 31,000 miles but the visors look a little worn for some reason...
Thanks again!
Old Mar 25, 2009 | 12:56 AM
Jacks02's Avatar
Jacks02
Another example why this forum is so valuable! Great writeup on the fix!
Old Mar 25, 2009 | 02:33 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Dee Gee with the save.. another pint owed.
Old Mar 29, 2009 | 11:20 PM
mazevedo's Avatar
mazevedo
Navigator
DeeGee-I just wanted to thanks for the R&D you put into this fix, I spent maybe 25 minutes implementing the fix to both sides and it they work like a champ. This forum is awesome!!
Old Mar 30, 2009 | 12:30 AM
bencini231's Avatar
bencini231
Old Mar 30, 2009 | 01:12 AM
DeeGee's Avatar
DeeGee
My pleasure
It took at least 30 mins of head scratching to work it out
Old Mar 30, 2009 | 09:57 AM
De_Vette's Avatar
De_Vette
Another happy customer, this place is great
To 2002 Convertible
