Urgent Coolant Question
Old Mar 25, 2009 | 02:05 PM
Munch's Avatar
Munch
St. Jude Donor '10
Default Urgent Coolant Question
So I just changed all the hoses on my 2000 coupe and am following the service manuals instructions for replacing the coolant but... it says to get the car up to 210 degrees while reving the engine to 3000 rpm at 30 second intervals but it won't get past 185 degrees. I have a 160 thermostat installed if that matters. Is 185 good enough or what should I do?
Thanks in advance.
Old Mar 25, 2009 | 02:13 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Thanks in advance.
good enough.
you can burp it with those instuctions later if you need to
Peace
Chip
__________________
..................Click for
Old Mar 25, 2009 | 02:15 PM
Munch's Avatar
Munch
St. Jude Donor '10
Thanks chip, that's kinda what I thought but wanted to make sure. By the way it's your braided hoses that I just put on and they look awesome!
Old Mar 25, 2009 | 02:17 PM
CCA Corvette Parts
Cool!
How the hands? lol
Peace
Chip
Old Mar 25, 2009 | 03:24 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
Thanks in advance.
the object of this exercise is to be sure the t'stat is open and passing coolant. it appears you have accomplished it. keep an eye on the coolant reservoir.
Old Mar 25, 2009 | 03:40 PM
Bill Dearborn's Avatar
Bill Dearborn
Sounds like the fans are coming on. You could unplug the fans and let the temp come up to 210. Doesn't matter what thermostat you have without air moving through the radiator its not going to cool much.
Bill
To Urgent Coolant Question
