Shocks
Old Mar 25, 2009 | 04:55 PM
Adoggy Phizzle's Avatar
Adoggy Phizzle
Default Shocks
I purchased my dream car last year after dreaming about the vette since I was ten years old. I am enjoying the heck out of it. My question, and I apologize for not being technically astute, is do the shocks have a shelf life based on milage of the car or years mounted? The car is a 99 with 12,500 miles on it. It has the Z51 package. I made sure to replace all the fluids as they were basically ten years old in the car. Does the same hold true for the shocks. If so, any suggestions on replacements. Thank you in advance.
Old Mar 25, 2009 | 05:18 PM
aleadfoot's Avatar
aleadfoot
I think mileage more than age kills the dampers. Seals will leak and ride will worsen but I have taken out shocks I thought were good and they were toast. SO if they aint leaking, I think you are good to go to at least 50k miles. If toast I went with C6z06 shocks $250 for all direct bolt on ride and performance improved
Old Mar 25, 2009 | 05:33 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I replaced my OE shocks with Bilstien Sports...much improved over stock and work well with lowered vettes...
Old Mar 25, 2009 | 06:01 PM
japc5's Avatar
japc5
With that kind of mileage the shocks should be good to go as long as the seals haven't dried up and they are not leaking.
I would be concerned with the tires and how old they are. If they are the originals you should consider replacing them.
Old Mar 25, 2009 | 09:15 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
If the ride feels good to you and the shocks aren't leaking, I'd leave well enough alone.
If you're looking for an upgrade, I went with Koni FSD shocks.
Old Mar 26, 2009 | 03:29 AM
AIKMAN8's Avatar
AIKMAN8
Coilovers! Enjoy!!!
Old Mar 26, 2009 | 05:47 AM
vetter79's Avatar
vetter79
Replaced mine with Koni FSD's. Ride's really improved over the 'Ol 99's OEM.
Old Mar 26, 2009 | 10:45 AM
Unless you see oil leaking from the shocks or the ride is bad, your shocks are probably still good. A number of forum members have replaced theirs with the C5 Z06 or C6 shocks.
To Shocks
