Center Console Problems
Old Mar 29, 2009 | 11:45 PM
Turbopower87's Avatar
Turbopower87
Default Center Console Problems
When I bought my vette the part that the center console lid clicks in to had fallen through the gap so that the lid would not latch shut. I recently had the center console out for the first time so I took the 10 seconds to fix it. Well it has only been a week and I've open the lid less than 10 times and the part has already fallen back through.
Is this a common problem or do I need to replace something? I'd like to be able to put my wallet in their occasionally and lock it. Or should I just epoxy the part that keeps falling through?
Old Mar 29, 2009 | 11:51 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Maybe a pic or two, Are the hinge screws tight?
Old Mar 30, 2009 | 12:10 AM
bencini231's Avatar
bencini231
Are you talking about the plastic piece that the lid fastens itself to when you close it? If I remember correctly it just snaps in so it may have a weak spot allowing it to fall out. If so you may be able to find a replacement and try it. Hope this helps.
Old Mar 30, 2009 | 09:30 AM
Turbopower87
The female part is the one that drops through. I'll see if they have that part cheap at the GM parts down the road. If not I guess I'll just epoxy it.
To Center Console Problems
