Shift Knob Removal
Old Apr 1, 2009 | 12:16 PM
97c5vette's Avatar
97c5vette
Default Shift **** Removal
I did a search but can't find anything
Can someone tell me how to remove the factory 6 speed shift **** from my C5?
Old Apr 1, 2009 | 12:26 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
First you must remove the shift pattern cap to expose the demon key that holds the shift **** firmly in place. To remove the shift pattern cap I used a thin plastic trim removal tool. You can easily make one from a thin piece of scrap plastic.
To remove the demon key, I used a narrow nose vise grip to prevent contact with the stock leather **** and eliminate the risk of any damage. With the vise grip firmly in place, use the flat side of a metal hammer to keep a steady rythm of tapping of the hammer against the elbow of the vise grip and the demon key will come right out as you continue to pull. Just let the vibration loosen the wedged metal demon key.
If you intend on changing the shift boot as well, be careful not to damage the plastic ring that the boot is attched to. The plastic ring also holds the boot in place in the console. This plastic ring is very fragile and will crack easily. These rings are not sold seperately so if you break it you will have to buy a new boot/ring for around $100 from a Forum vendor, more $ from your local dealer, separate the stock boot from the ring and attach the new boot to the ring.
Here are some links that will be of help:
http://www.vetteessentials.com/instr...t_install.html
http://augerresources.com/instructio...ebrakeboot.htm
http://www.redlinegoods.com/C5install.shtm
Old Apr 1, 2009 | 12:44 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
everyone should own a set of these. $5 at Harbor Freight, made of nylon
Old Apr 1, 2009 | 12:45 PM
Mike98SilVert
http://forums.corvetteforum.com/c5-t...hift-****.html
Old Apr 1, 2009 | 01:55 PM
That's the exact method I used to take mine off when I installed the VE shift ****. It's the way Ken King told me to do it and it worked like a charm.
Old Apr 1, 2009 | 02:37 PM
Dave68's Avatar
Dave68
This'll show you how I've always done it:
http://www.conceptualpolymer.com/corvette_install.htm
Old Apr 1, 2009 | 05:31 PM
02 C5man's Avatar
02 C5man
I just drilled a small pilot hole followed by a self tapping screw leaving the screw out about 1 inch. Then I could get the vicegrips on it, hit the grips with a hammer and it came out in one hit. I tried everything else for hours with a lot frustration and no luck.
To Shift Knob Removal
