Column Lock Nightmare!
Old Apr 2, 2009 | 04:40 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by Y2KMagRedLady
Get a call today stating that the part that is needed is on backorder until the END OF MAY!!!
The dealer is lying to you. There is no part to fix this problem. Deny any recalls to be performed. Get the car back home and install the CLB. tow it if you have to. The steering wheel can be unlocked by yanking it really hard several times. once that is released install the CLB.
Old Apr 2, 2009 | 05:43 PM
The Dark Knight's Avatar
The Dark Knight
Does anyone know if they fixed that problem by time the '04s came out, or is this a problem all C5s have?
Old Apr 2, 2009 | 06:21 PM
GK's Avatar
GK
There was a user that posted something like "If your VIN ends with xxx or higher you are ok" meaning a CLB is not needed.
Any validity to this?
Old Apr 2, 2009 | 08:39 PM
smitty2000's Avatar
smitty2000
I just went through thilast week. If it has been more then 12 months since it was replaced they will not pay for it. Just like you they told me that the part could not be found and would cost $350 when they did find it. I ordered a CLB from COH and told the dealership not to fix it until I was able to try that. At that point WOW they where able to locate 1. Someone dropped the ball and they fixed it but gave me $100 off. I am keeping the CLB for back up.
Old Apr 3, 2009 | 12:38 AM
jclarksnakes's Avatar
jclarksnakes
People who take their C5 to the dealer for any problem before doing research on this forum are making a mistake. If you are having a column lock problem the dealership is the very last place to go. Get a CLB and install it yourself.
Old Apr 3, 2009 | 01:04 AM
latenightlarry's Avatar
latenightlarry
Default column lock
Just last weekend the service column lock warning came on but the steering wheel isn't locked even when the key is out. whats up with that? Service or not?READ THAT a relay or something like was the fix any thoughts. thanks
Old Apr 3, 2009 | 02:00 AM
latenightlarry
Default column lock
yes i'm the original owner
Old Apr 3, 2009 | 09:24 AM
Corvettes of Dallas's Avatar
Corvettes of Dallas
Default CLB at Corvettes of Dallas
We have what you need --- If you need a CLB sent out, please call me direct and we will get you back on the road.
Todd
Old Apr 3, 2009 | 11:19 AM
Drewstein's Avatar
Drewstein
I mean really? They just took you for $250 and you're ok with that?
Old Apr 3, 2009 | 01:07 PM
TEXHAWK0's Avatar
TEXHAWK0
Just unreal that my car will be at the garage for 2 months!!!
So once they take care of this repair of the Steering Harness it would be recommended to install the bypass?
Thank you for listening to my whining!!
Find out what part the dealer is trying to order.
Whatever you do, don't let them tell you that you need to replace the actuator to get a working system.
The aftermarket CLB kits leave the actuator disconnected, and the bypass relay simulates the actuator signal to the BCM.
Even the GM Harness K relay kit will work with the actuator disconnected, even though it was designed to keep the actuator on the circuit. (You hear the actuator cycle even though the lockplate is removed and the column cannot lock.)
Old Apr 4, 2009 | 09:30 PM
Y2KMagRedLady's Avatar
Y2KMagRedLady
So after being on the phone with GM enough they magically found a part and it will be at the dealership on Monday. When I get my car back I'm thinking I'm going to install the CLB. Is this something difficult to do....remember I'm a woman!! Thanks for any pointers!!
Old Apr 8, 2009 | 10:32 PM
robsc501's Avatar
robsc501
Hi There:
I'am looking at my GM VIS summary.On 9/2/05 the body computer(control) module was replaced at 7692 miles.On the same day: v1145-04006-perform reprogram & functional test on manuals.I was not the owner of this 01 vette at that time. I'am looking at the letter that gm sent to the original owner.This letter said : THIS IS NOT A RECALL but if you have the pull key & wait 10 seconds message displayed on the DIC you were to bring the car in for service. I would like to know what was involved in the repair in 2005. This letter is dated feb. 2006.This repair work was done at Kerbeck,s in Atlantic City N.J. This car was purchased new from Kerbeck.With the key removed my wheel is locked. Key on unlocked. Thats the way its supposed to work. I have owned the car almost 3 years without any problems. 16,600 on the clock Do I have a potential problem? Is a CLB required?
Thanks.
robsc501
Old Apr 9, 2009 | 04:25 AM
  #33
Y2KMagRedLady
Originally Posted by robsc501
Hi There:
Thanks.
robsc501
I had the same issue. Mine was recalled and "repaired". I also had the letter dated Feb 2006, which expired Feb 2008. I was in the same boat as you and my 2000 just turned 17,000 miles and out of no where my column is locked! I would DEFINITELY install the CLB before the same thing happens to you as it did me! If I could only turn back time!!!
Old Apr 9, 2009 | 04:28 AM
  #34
Y2KMagRedLady
Originally Posted by 8VETTE7
Here are the install instructions that you should use:
http://www.ls1howto.com/index.php?article=24
Print them off and read them carefully. They have some pretty good pictures so you can see what you are getting into. If you have even the least bit of capability you can install the CLB. You will need a flat blade screw driver, a Torx T-15 screwdriver and a pair of needle nose pliars. All are available at a local hardware store for probably under $10. If after reading the instructions you are not comfortable trying this, go to a local Corvette Club meeting and I'm sure that you can find a couple of tech type people that would install it for a couple 6 packs of their favorite malt drink. If you attempt this yourself allow about an hour to do it and follow the install instructions EXACTLY.
Thank you for the link. I think I will be able to do it, I'm fairly good with fixing things but needed the clear instructions like yours to be able to do the job! I appreciate your help!
Old Apr 9, 2009 | 05:11 PM
  #35
tommie's Avatar
tommie
Originally Posted by Drewstein
Get your car out of the dealer NOW. Do not let them touch it!!!
I can't count how many people do not listen and end up having a ton more trouble.
Order a CLB from COH and install... problem solved.
just did mine 1 hr and $50 later..problem solved!!
