ebrake problem
Old Apr 1, 2009 | 09:45 PM
pdvale's Avatar
pdvale
Default ebrake problem
Hi,
I just noticed a problem while trying to open the trunk on a 02 Z06 while the car is running. The ebrake light on the dash works (when you start the car all the dash lights go on) but when the ebrake is on, the light on the dash is off. This stops the button from working to open the trunk. If I open the drivers door, the button will open the trunk.
Any help/ideas would be appreciated.
Thanks,
Paul.
Old Apr 1, 2009 | 11:42 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Just sounds like a bad connection --- I'm not 100% sure on this, but good luck to ya...
Bump for ya...
Old Apr 1, 2009 | 11:59 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
How long has it been this way? There should be a switch that opens and closes when you put on the emergency brake....not sure if it's under the center console but might be the problem. It's probably wired to something and it's telling the trunk the brake needs to be on and it isn't...then the door maybe does the same thing but it's working. Could be the switch or connection got disconnected and it's that simple.
Old Apr 2, 2009 | 12:41 AM
pdvale's Avatar
pdvale
It's only been a few days, I finally figured out that something was wrong this morning.
Would I remove the center arm rest/console to see the switch or do you think it is under the car somewhere?
Sorry for the noob question... I just drive the thing!
Old Apr 2, 2009 | 01:46 AM
MyVetteDream
No worries about asking questions --- that's why we're all here.
Hope you get your answer....
To ebrake problem
