Drilled? Slotted? Drilled & Slotted? Advice? Thanks
Harvey A
^^There have been a lot of threads on this subject. It all boils down to what you plan to do with the car and personal preference. If you plan to track the car (HPDEs) then get plain rotors.
If you drive the car on the street you can pick any rotor you want. Just make sure it will work with your rims/tire and brake calipers.
Cross-drilling and slots are just for bling, and really don't have any real function with modern braking systems.
The Track-specific Viper ACS and ultra-incredible performance Caparo both have slotted-only rotors. While I agree that drilled holes are bling. This is certainly NOT true of slots, as they were the ONLY way I could run the excellent OEM pads without getting the dreaded uneven pad deposits and resulting pulsating brake pedal syndrome.
In addition, instead of ending up with burnished and hardened pads after 5 years, my C5's pads are always like brand new - kinda like a pencil eraser that is shaved slightly before every use. It does a better job for obvious reasons.
Even the new Cadillac CTS-V, haulin quite a bit more weight than our C5s, comes with slotted-only rotors. GM finally got it right!
The super high end rotors are ceramic-big $$$$. Slotted rotors are "OK", cross drilled is probably useless in most cases, they are prone to cracking around the holes. I've seen some that are dimpled (the hole is not drilled through).
Yea, that's why all the new Z06 and ZR1's don't have them
They are just for looks!
^^Read the link. You might learn something. At one time the holes did serve a purpose. Your brakes convert mechanical energy into heat. The rotors are heat sinks. The more mass the rotor has the more heat it can hold. Holes reduce mass!! Second, the holes reduce friction as the holes reduce surface area.
^^The biggest reason given for slots is that they wipe away the glaze from the brake pads. Of course, they also act as cheese graters on the pads. Hence the clean look. Of course it shortens the brake pad life also.
^^The real high end rotors are carbon. The big advantage of carbon is weight. The ability of iron and carbon to hold heat is about the same. However, when racing weight matters.
