difference in ls1s
Old Apr 3, 2009 | 07:52 PM
kevink89's Avatar
kevink89
Default difference in ls1s
a good part of me says no but im just not sure if there is a difference between a ls1 in a camaro and the ones in corvettes can anyone help
Old Apr 3, 2009 | 08:19 PM
Cordes Performance Racing's Avatar
Supporting Vendor
no difference besides how the accessory's are configured. same heads/tune/cam/intake/rockers/pistons/ not a dang thing different. sorry had a guy argue w/ me that the ls1 in the f-body was inferior and they did not have the same 350 hp.
Old Apr 3, 2009 | 08:25 PM
fixvet's Avatar
fixvet
But isn't the F-body rated with just a bit less HP, because of their restricted exhaust system? The engines are the same though!
If I ever sold my C5, I would be driving a 2002 f-body for sure! Like they say, it's just a steel corvette!!
Old Apr 3, 2009 | 10:45 PM
Supporting Vendor
no. f-body's consistently dyno a little higher stock than c5's because the solid axle allows for less hp to be sucked up by the drivetrain.
Old Apr 4, 2009 | 12:30 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Here's a related question then, why does the '99 Corvette LS1 engine cost more than all the other LS1's? What's so different about it that rates a much higher price?
Old Apr 4, 2009 | 06:25 AM
kevink89's Avatar
kevink89
thanks for the input guys and do frc motors rly cost more that kinda sucks since thats wat im hopin to get lol and it does make sense that a irs rear would eat more hp than a solid axle but vetets r still lighter and i always called my old camaro a young mans corvette
thanks for the help guys
Old Apr 4, 2009 | 06:26 AM
kevink89's Avatar
kevink89
and i thought thay always purposely underated camaros numbers to make the vette look better since it was over twice the price and alot of ppl just look at wats got more power
Old Apr 4, 2009 | 06:34 AM
NC99's Avatar
NC99
My 2002 Z28 6-speed dynoed 319 RWHP bone stock. With only an air lid, sub-frame connectors, SLP LM and drag radials, I was consistently running 12.50's-12.60 at 1400' elevation. It had 353 RWHP after the mods. I have lost count of the stock C5's that I blew away at the track. Here are two videos of me at the track and dyno with the 2002 Z28. Awesome car, but not the quality of a Corvette. The engines are the same, btw.
http://www.youtube.com/watch?v=yDzuyuBM0pw
http://www.youtube.com/watch?v=aWbc6HLILhY
Old Apr 4, 2009 | 12:41 PM
Supporting Vendor
i don't believe for one second your car w/ a cat-back and lid dyno'd 353 rwhp.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Apr 4, 2009 | 01:16 PM
NC99's Avatar
NC99
Well, it did. That car was a factory freak and was bad ***. It dynoed 340 RWHP, then I installed gutted cats and got 13 RWHP from that alone. Nothing else was done to this car. Nothing. I dynoed at two different shops, over 70 miles from each other.
Even though I now own a Corvette, it was fun to watch C5's try and catch me at the track. I have driven C5 ZO6's and they are not quicker than my Z28. They are pretty equal but if push came to shove, I think my Z would beat a stock ZO6.
Either way, 353 RWHP from a lowly Z28!!
Old Apr 4, 2009 | 01:47 PM
Supporting Vendor
your car w/ 353 rwhp trapped 110 now watching the video's it's obvious you can drive fine so i'm not questioning you in that aspect in any way shape or form. but 353 rwhp does not give you 110 mph in a f-body you should have trapped a little higher than that. your car ran good as is obvious from the video but those dyno numbers are a little high.
Old Apr 4, 2009 | 03:58 PM
NC99's Avatar
NC99
Not at all. When you launch an f-body 6-speed off the line, the clutch was made to slip due to added restriction, and that it does! The rear end is warranted, but the clutch is not. GM did this to protect their very fragile 10-bolts which are prone to shattering under load with little to no wheel spin. My 60' times were 2.0-2.2 because of this.
There is DIY "drill mod" to fix this, but I never did it because I was happy with the performance that I had and plus, using drag radials with no spin off the line (typically), I didn't want to shatter my 10-bolt. For those ET's, the trap speed is typical but if I could have launched hard at 5000k and got all that power to the wheels without the clutch slipping, my 60' times would have improved by probably 3-4 tenths. If I launched at anything higher than 2500 RPM, that damn clutch would slip and wouldn't help nor hurt my 60' times.
Old Apr 4, 2009 | 06:01 PM
tail_lights's Avatar
tail_lights
Should be, many trap well over 110, even in that DA. They have a huge gearing advantage (for a stock car) with that MN12 tranny. I see we may be getting into the whole quicker/faster debate again though so just food for thought, don't want to kick start that debate again
Old Apr 4, 2009 | 08:25 PM
NC99's Avatar
NC99
No need to debate this at all. My dyno sheets, time slips and bracket racing trophies are enough for me. That was a great car but I like my Corvette much better.
My original point was just that LS1 engines are the same, with the exception of the 2001 and 2002 Z28 because they came with the ZO6 manifold which was worth 15 extra HP over previous years LS1's. Either way, the LS1 is a powerful engine which responds to bolt-ons very, very well.
Old Apr 4, 2009 | 09:03 PM
Supporting Vendor
i did not question your launching or need a lesson about the drill mod. i modify f-body's vettes, vipers, etc for people so i know what i'm talking about. and usually a quicker 60ft. equals a lesser trap. what i'm saying is your mph and dyno do not match simple as that.
Old Apr 4, 2009 | 10:18 PM
tail_lights
Man if you are bracket racing (and winning) with a stick you are the man Where is New Bern? My fiance is from Fuquay.
Old Apr 4, 2009 | 10:23 PM
NC99's Avatar
NC99
This was when I lived in Ohio. I miss the weekends at the tracks. We would go to 2 or 3 per week and race. New Bern is in eastern NC. About 60 miles from Greenville and Jacksonville. Never heard of Fuquay??
To difference in ls1s
Old Apr 4, 2009 | 10:26 PM
tail_lights
Well technically its Fuquay-Varina and its in 'the triangle'. I'm not from there so this makes no sense to me
Old Apr 5, 2009 | 07:44 AM
NC99's Avatar
NC99
I just looked that up on the map. New Bern is about 2+ hours from Fuquay-Varina. I've only lived here since 2007 and many things don't make sense to this northern boy. I love everything about NC except many of the old, OLD laws still on the books that don't make any sense at all. When I first moved here I worked as a corrections officer for the Sheriff's Department and man, the old school laws really screw a lot of people, BAD!!!!
Old Apr 5, 2009 | 08:28 AM
AU N EGL's Avatar
AU N EGL
track ? as in Drag strip?
or road course?
