Short shifter install...difficult?
Old Apr 5, 2009 | 07:39 PM
time4prime2shine's Avatar
time4prime2shine
Default Short shifter install...difficult?
Evening everyone..
Are the short throw shifters very difficult to install or is this something that is a big hassle?? Im thnking of buying one (havent decided which so feel free to give your opinion there as well...hurst??)....Any negatives to this mod or??? Not lookin to race...but just thought be a cool mod and fun to have....thanks for the advice n help
Old Apr 5, 2009 | 07:52 PM
Patches's Avatar
Patches
Done it a few times - not difficult at all. There are different opinions on whether the force these short shifters require to shift is appropriate or not so you may want to see if someone local can let you feel how their aftermaket shifter works in a C5. Here are links to some of my installs.
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
http://forums.corvetteforum.com/c5-g...tml?highlight=
http://forums.corvetteforum.com/c5-g...installed.html
Old Apr 5, 2009 | 07:53 PM
JCamaro's Avatar
JCamaro
Originally Posted by time4prime2shine
Evening everyone..
Took me about 1/2 hour to install. It does make the shifts firmer and more precise.....but it requires a little more "effort" to shift....
Old Apr 5, 2009 | 08:17 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I just installed the Hurst shifter in my Pace Car. Start to finish was about 45 minutes. I used a Torx15, a 10mm socket and a small screwdriver. I also used a needle nose vise grips and a small hammer to remove the daemon key. Easy.....
Old Apr 5, 2009 | 08:29 PM
rickko's Avatar
rickko
Patches has great writeups on the install. I followed one of them about four years ago when I installed a Hurst.
Patches!
How does it feel? Well, it definitely takes more effort than stock. When my girlfriend drives I can tell it's not much to her liking.
Good luck!
..rickko..
Old Apr 5, 2009 | 08:33 PM
time4prime2shine
great info guys...I never considered the extra effort to shift...hmm....overall, do u think it was worth the mod or no??
Old Apr 5, 2009 | 08:38 PM
JCamaro's Avatar
JCamaro
stock shifter = satan
Aftermarket Shifter = redemption
This is true about pretty much every vehicle....at least that I've driven...
Old Apr 5, 2009 | 08:50 PM
71corv's Avatar
71corv
St. Jude Donor '08
I feel that the change to a short throw shifter is worth the time and money. Have changed the shifter in my 02 Z06 to a C6 Z06 shifter to a MGW shifter.The MGW is stiff at first, but after a little use, you will notice that it does feel just right-firm but not over bearing.
Gene
Old Apr 5, 2009 | 08:52 PM
ALLEGRO's Avatar
ALLEGRO
My twist was to just shorten the existing OEM shifter. I cut a little over an inch off and REALLY like the results.
Old Apr 5, 2009 | 08:54 PM
TPA Z06's Avatar
TPA Z06
Gene
Well said!
Old Apr 5, 2009 | 09:06 PM
blacksedan87
I have a B&M Ripper Shifter in my black car, it's tight with notchy throws, and I love it. The Pace Car is a more relaxed ride, and the Hurst with it's slightly softer feel and easier movements is just the perfect compromise.
All I can say is stock sucks, and the difference will take an all ready enjoyable drive and make it better!
Old Apr 5, 2009 | 09:13 PM
time4prime2shine
great info again....im doing it!!!!!! ...while im at it...what shift **** are u guys using??? (yes i know theres been load of threads on that and this...but what the hell!)
Old Apr 6, 2009 | 08:15 AM
bhoch's Avatar
bhoch
I am wanting to do this as well.
Old Apr 6, 2009 | 09:16 AM
B-Vette's Avatar
B-Vette
I'm using the MGW gripper shift ****, (satin finish). Good quality and great feel.
Old Apr 6, 2009 | 12:52 PM
shadeshift's Avatar
shadeshift
Not hard at all...took 45 mins as everyone else said. Just try not to lose anything. Maybe have a magnetic pick up tool handy just in case. They're always good to have around. Also, go with the MGW, you will not be sorry. I'm running the MGW with gripper **** and love it. Reverse can be a little tough but the rest is sweet as candy.
Old Apr 6, 2009 | 12:57 PM
TEXHAWK0's Avatar
TEXHAWK0
The hardest part is getting the factory shifter **** off.
Old Apr 6, 2009 | 01:57 PM
GreenDream's Avatar
GreenDream
It is well worth the swap out and not difficult at all. Whatever one you choose is much better than stock. I replaced a Hurst with MGW and love the MGW. If you are thinking of going Hurst, PM me and I can make you a good deal.
To Short shifter install...difficult?
Old Apr 6, 2009 | 03:22 PM
Navyvette04's Avatar
Navyvette04
Good info, thanks for posting.
Old Apr 6, 2009 | 03:59 PM
gofastcar's Avatar
gofastcar
I'm not a DIYer's at all. And I did it without any problems!
Go for it!
Old Apr 6, 2009 | 04:06 PM
JiVe's Avatar
JiVe
HELP, I'm trying to remove the center counsel sand arm rest in a covertible, is there a trick. the waterfall is screwing me up
