Window Valet Issue
Old Apr 6, 2009 | 01:02 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Default Window Valet Issue
For the last several months, when I use the Valet to raise the windows, the driver's side only goes about half way up and then both will lower. Seems to have too much pressure from the door panel/weather stripping. If I pull it up past the resistance, the windows will then continue to close as designed. But I can't walk away and use the Valet.
Anyone run into this? If so, how is this corrected.
P.S. Worked fine since installed four years ago. Now this.
Old Apr 6, 2009 | 01:11 PM
Munch's Avatar
Munch
St. Jude Donor '10
Never had that problem but perhaps it just needs to be re-calibrated?
Old Apr 6, 2009 | 01:18 PM
PY310L's Avatar
PY310L
Never had a problem with it. Been using it over a year now. Sounds like it's the module itself. Try removing it and reinstalling it.
To Window Valet Issue
