diy vararam install with pics
Old Apr 6, 2009 | 07:04 PM
Z06streetracer's Avatar
Z06streetracer
Default diy vararam install with pics
i cant find any
Old Apr 6, 2009 | 07:16 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Cajundude Vararam install how-to This is the one I used. Beware, depending on your year you may or may not need the bushings between the intake ducts and the front of car. Mine is an 02 and required two up top and one on the bottom to get the proper clearance to get my fan shroud back in with clearance. Good Luck
Old Apr 6, 2009 | 07:18 PM
e6bailey's Avatar
e6bailey
http://www.zbramotors.com/vararam/VaraRam.html
Google .22 sec 1st result
Old Apr 7, 2009 | 01:31 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
It's a bit easier to get to the fog light bolts through the head light openings after removing the head light tops and bezels. The job isn't that bad at all. It can get tricky but the results are solid.
Old Apr 7, 2009 | 11:30 AM
BitViper's Avatar
BitViper
First real "challenging" mod I did was Vararam....is very straight forward...but a PITA to do....
Just dive right in..its mostly plastic stuff
Old Apr 7, 2009 | 02:59 PM
Z06streetracer
thanks alot guys
i actually just lowered my 02 z with the help of you guys on here
i did it by the stocks bolts it looks awsome
i am going to get the vararam now
Old Apr 7, 2009 | 05:01 PM
BitViper's Avatar
BitViper
God help you my son.....
Old Apr 7, 2009 | 06:49 PM
darbn's Avatar
darbn
The Vararam install isn't that bad. I did it in the garage of my condo. I found out after having the top torn apart that the jack I had did not fit under the car. I proceeded to do the install by flashlight with no jack. It only took a bit over 3 hours. Good luck.
Old Apr 7, 2009 | 07:23 PM
Z06streetracer
hahha damn im sorry about that i hope i dont have that much trouble
To diy vararam install with pics
