Wheel Sizes
Old Apr 7, 2009 | 05:44 PM
VetteStir's Avatar
VetteStir
Default Wheel Sizes
Hey guys, just bought a 2000 and have a dumb question. What are the stock wheel sizes? Thanks
Old Apr 7, 2009 | 05:50 PM
Bills03Coupe's Avatar
Bills03Coupe
17 x 8.5" wide in front, 18 x 9.5" wide in rear (This is assuming you have the thin spokes)
Old Apr 7, 2009 | 06:35 PM
VetteStir's Avatar
VetteStir
Sure do. Figured I'd get a quick answer... Thanks!
Old Apr 7, 2009 | 08:37 PM
VetteStir's Avatar
VetteStir
Will 17 x 9.5 fit on the front??? and... 18 x 10.5 on the rear???
Old Apr 7, 2009 | 08:58 PM
Tonycpa's Avatar
Tonycpa
Yes
Old Apr 11, 2009 | 06:20 PM
VetteStir's Avatar
VetteStir
Anyone have a pic with this size wheel on the stock size tires?
Old Apr 11, 2009 | 06:22 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
17x9.5 and 18x10.5 are the stock C5 Z06 sizes, and they fit all C5's fine.
Old Apr 11, 2009 | 08:43 PM
NOT2MELO's Avatar
NOT2MELO
A question about tires to fit those factory sized C5 rims 17 x 8.5" front and 18 x 9.5" rear.
Still trying to figure out this size issue, the rear must be 1/2 larger diameter then the fronts, can it be too large?
Was looking at the Nitto Invo's but also the Nitto NT05's.
-The Invo 245/40/17 fronts 24.69" dia and the 295/35/18 rears with 26.02" dia so thats 1.33 dia larger.
-The NT05 255/40/17 fronts, 25.08" dia and the 295/35/18 rears with 26.18" dia so thats 1.1" dia larger.
Dont know if that will cause any issues or not with a 1" dia larger size and dont want to buy the wrong tires and get AH/TC problems.
Old Apr 11, 2009 | 11:12 PM
VetteStir's Avatar
VetteStir
OK bottom line is, everything I can find on the internet says that the largest rim you can put on a 245/45/17 tire is a 17 x 9.0.
Has anyone put a 9.5" wide rim on this tire successfully? If so, did it look and ride right?
Old Apr 11, 2009 | 11:35 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I sent this in the Pm.
I have 17x9.5 on mine. They roll straight with no problems.
Rotors have been painted red BTW.
Old Apr 12, 2009 | 12:22 AM
MY64's Avatar
MY64
What if the Z06 rear brake cooling ducts and inner fender panels have been added? Will the 18x10.5 and tire clear the duct. Right now the stock wheel and tire barely clears (1/4-3/8" clearance). If the stock wheel offset is 65mm what would be the minimum new wheel offset?
LEC
To Wheel Sizes
