Having problem installing front license cover
Old Apr 8, 2009 | 07:27 PM
vinrmc86's Avatar
vinrmc86
Default Having problem installing front license cover
I ordered this cover off of ebay it had the spot for the holes marked but they were not cut out so I cut it out and tried to install it. Should it be this difficult there is just twos screws its hard me to see and screw it in. Here is some pics does this look ok to you guys?
Old Apr 8, 2009 | 07:43 PM
vinrmc86's Avatar
vinrmc86
help?
Old Apr 8, 2009 | 08:02 PM
TEXHAWK0's Avatar
TEXHAWK0
Cannot see the pictures.
Old Apr 8, 2009 | 08:12 PM
2vette2's Avatar
2vette2
Veteran: National Guard
St. Jude 15 Year Donor
St. Jude Donor '09-'25
ditto
vinrmc86's Avatar
vinrmc86
for some reason that site is down here is the pics.
http://s692.photobucket.com/albums/v...ent=front2.jpg
http://s692.photobucket.com/albums/v...rent=front.jpg
Old Apr 8, 2009 | 08:19 PM
91LSMAN's Avatar
91LSMAN
It should be two screws on the bottom. The one I installed on my dad's vette, the holes were there-no issues, altough getting a small screw driver in there to screw in the holes is a bit tight.
Old Apr 8, 2009 | 09:16 PM
vinrmc86's Avatar
vinrmc86
what do u guys think?
Old Apr 8, 2009 | 09:19 PM
DeeGee's Avatar
DeeGee
It looks a little low at the right. Are the screws in tight?
Theres no trick to it. There are only the two screws at the bottom
Old Apr 8, 2009 | 09:22 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
It should be no big problem. What "91LSMAN" posted about the small screw driver is correct. At the top you should be able to slide it up and in, and than screw the two screws at the bottom, but it is tight, and you will need a small screw driver. I had to lie on the ground to do mine.
Old Apr 8, 2009 | 09:37 PM
91LSMAN's Avatar
91LSMAN
WAIT A MINUTE:
vinrmc86: Are you trying to put the screws in the TOP of the cover? The screws for the cover go in at the bottom. There are places for other screws behind the cover, but those are for when a front plate is used.
Old Apr 8, 2009 | 09:45 PM
vinrmc86's Avatar
vinrmc86
No, I am using the bottom screws for some reason there not lineing up.
Old Apr 9, 2009 | 01:22 AM
91LSMAN's Avatar
91LSMAN
I know this might sound weird, but take the cover off and take a picture of your holes.
Old Apr 9, 2009 | 06:39 PM
vinrmc86's Avatar
vinrmc86
ok will do
Old Apr 9, 2009 | 06:45 PM
VetteDawg's Avatar
VetteDawg
screw the screws. use velcro. mine's been on with velcro for years.
To Having problem installing front license cover
