Headlight/Parking light issue...
Old Apr 10, 2009 | 09:39 PM
RSuperfreak3's Avatar
RSuperfreak3
Default Why do my headlights open when parking lights are on?
When I turn my parking lamps on, my headlight doors open with the lights off. I have a gear that needs to be replaced on one of the headlights (hidious grinding noise when you close the headlights) and was wondering would this cause the doors to open when you turn the switch to the parking lights? I know I have seen something on this before but the search function seems to be out of service, so I will just ask. Please help.
Old Apr 13, 2009 | 12:58 AM
DeeGee's Avatar
DeeGee
That would cause that problem. Once you fit new brass gears in the offending headlight motor it should be back to normal
Check out Leaftye's sticky in C5 Gen and run down to headlight motors. You'll find all you need to fix the problem
