Differential Fluid
Old Apr 13, 2009 | 12:36 AM
mag red vette's Avatar
mag red vette
Default Differential Fluid
The dealer is suggesting changing the rear end fluid with ATF. They claim this is the latest recommendation from GM in order to deal with noisy clutch packs. Any thoughts or suggestions?
Old Apr 13, 2009 | 01:14 AM
DeeGee's Avatar
DeeGee
Sounds like the latest "bring in some $$$ to the Dealer" scheme to me
The recommended fluids are:
Rear Axle Limited-Slip Differential: SAE 75W-90 Synthetic Axle Lubricant, GM P/N 12378261 (Canadian P/N 10953455) or equivalent meeting GM Specification 9986115. With a complete drain and refill add 118 ml (4 oz) of Limited-Slip Differential Lubricant Additive GM P/N 1052358 (Canadian P/N 992694) or equivalent
DEXRON®-III Automatic Transmission Fluid is the recommended lubricant for the Manual Transmission but the book says that manual transmission fluid doesn't require changing. Auto fluid change is changed at 50k if hot/hilly or high performance use or 100k for regular use.
Is your clutch particularly noisy?
Old Apr 13, 2009 | 01:39 AM
KRISCO's Avatar
KRISCO
Not for me
Old Apr 13, 2009 | 07:42 AM
moserbe's Avatar
moserbe
NOT in my car!!!! Sounds like to me.
Old Apr 13, 2009 | 07:56 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Royal Purple Max Gear 75w-90, or the Amsoil alternative :thumbs
Your dealer is trying to get business, thats all.
Old Apr 13, 2009 | 11:23 AM
mag red vette
Just to clarify, it's time to change the rear end fluid anyway. I am just wondering whether using the "latest and greatest" from GM is the way to go. The cost is the same regardless of which fluid is used.
Old Apr 13, 2009 | 11:26 AM
moserbe's Avatar
moserbe
ATF is way too light a fluid IMHO. It's your rear end, do what you think is right.
Old Apr 13, 2009 | 11:35 AM
I think I'd stick with the differential fluid. Perhaps one of the forum auto vendors could chime in on this supposed recommendation from GM.
Old Apr 13, 2009 | 01:04 PM
DeeGee's Avatar
DeeGee
This is the spec Jack
Old Apr 13, 2009 | 01:09 PM
DeeGee's Avatar
DeeGee
No need to change it. If I was going to change it anyway, I'd use the specified lubricant. JMHO
Old Apr 13, 2009 | 01:27 PM
J S Machine
Sounds to me like your dealer needs the profit from a rearend job and they thought you seemed like a good candidate.
Old Apr 14, 2009 | 06:11 PM
okbkvette's Avatar
okbkvette
actually, not sure sure its the usual b.s. I've had an ongoing "noise" from my diff for 3 years. It's been to the dealer three times for this. Each time, they've changed the fluid. Works ok for couple months, then sound comes back. Basically a grinding, slow speeds, when turning. Best way to demonstrate to service guy was lazy s in the parking lot. a groan, groan, groan sound.
Took it back 2 weeks ago and hit them hard, documented the crap out of them, and asked for them to replace diff. They wouldn't do it. They cited that GM bulletin, said they have had other vettes in there over last year with same sound problem, and the "new" super fantastic, whatever lube will do the trick this time.
So, I think there is a small problem out there, at least I've had it. I hope this time is the charm,and the sounds stops coming back.
I've got 31,000 miles on mine
To Differential Fluid
