Has anyone else ever felt this
Old Apr 14, 2009 | 07:43 AM
chreaponecoat's Avatar
chreaponecoat
Default Has anyone else ever felt this
A drift or wonder when driving? Always inside the lane or when I change lanes. If I change lanes it will stop so I think it is following the grooves in the road. This does not happen all the time. Most of the time it is at highway speeds. Thanks Bob
Old Apr 14, 2009 | 08:00 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
You're "tracking" Bob. Basically, our tires are wider than the normal "groove" made by regular size car tires. So, when you encounter this groove in softer asphalt, heavely traveled roads, you're gonna wonder from side to side a bit.
Mostly it isn't anything to worry about. But, there are some roads around here that the groove is so pronounced, it will actually try to throw my car into the other lane.
Old Apr 14, 2009 | 08:11 AM
You are following the groves in the road - just be prepared and use the steering wheel to correct.
Old Apr 14, 2009 | 09:54 AM
Dave68's Avatar
Dave68
It can also be a loose sway bar bolt on the right side. You might want to check it out, the next time your car is in the air.
Old Apr 14, 2009 | 10:01 AM
tracks03's Avatar
tracks03
I've noticed something similar. When on an open stretch on a 4-lane highway, I will lighten my grip on the wheel to check if my car is pulling either way. The 'vette seems to know it owns the road b/c it will drift over and straddle the two lanes!
Old Apr 14, 2009 | 10:07 AM
urfubar's Avatar
urfubar
Ive noticed the same thing and everything was thoroughly checked out...might run flats play a roll in this?
Old Apr 14, 2009 | 10:10 AM
Vega$Vette's Avatar
Vega$Vette
I "wonder" all the time when I'm driving
Old Apr 14, 2009 | 10:54 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Some people also call it "Tramlining". If its severe, then you might wish to have the alignment checked. Also, if the tires are wearing on the inside edges, this will tend to cause this tramlining or tracking to be worse.
Old Apr 14, 2009 | 11:04 AM
10U 99's Avatar
10U 99
vehicles with wide rubber are more susceptible to this condition. it can be cured by switching to P225-75/15s.......... or just get used to it
Old Apr 14, 2009 | 11:09 AM
redrckt97's Avatar
redrckt97
I had pretty bad tramlining on my 97 which got steadily worse as my old BFG tires wore -- when I replaced them with new Firestones and had a good alignment, the problem was GONE. The old tires were worn on the inside edge as mentioned above due to bad alignment (think prior owner may have had it set more for track use).. As others have said, this will always be a tendency with such wide and low profile tires but proper alignment helps a Lot.
Old Apr 14, 2009 | 11:28 AM
Sinister-one's Avatar
Sinister-one
Old Apr 14, 2009 | 04:13 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
yup, happens to me also.
matter of fact, it would also happen in my TA and Z28
Old Apr 14, 2009 | 04:21 PM
NavyDoc2007's Avatar
NavyDoc2007
I changed from the Goodyear runflats to Michelin runflats and I don't have that problem anymore. The ride is much better as well.
Old Apr 15, 2009 | 03:42 AM
PierEagle's Avatar
PierEagle
The problem seems worse with the Goodyears when they are about 50% worn. The Michs and a 4 wheel alignment made it go away.
Old Apr 15, 2009 | 07:19 AM
Stevo92z28's Avatar
Stevo92z28
Ya my car wanders pretty bad. Its normal in almost any vehicle with wide rubber.
Old Apr 15, 2009 | 07:28 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Same here so not to worry. It surprised me when I first bought the car but I've come to expect it because of the tires.
Old Apr 15, 2009 | 07:53 AM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
To Has anyone else ever felt this
Old Apr 15, 2009 | 08:25 AM
homewrecker's Avatar
homewrecker
I got used to it...like my eyes, my car wanders.
Old Apr 15, 2009 | 01:21 PM
itzza427's Avatar
itzza427
I' check it out on a good straight stretch that is clearly level(no ruts)! If it still wanders or pulls you may want to get your alignment checked!
Old Apr 15, 2009 | 05:47 PM
egm262's Avatar
egm262
In my case the loose bolt was on the left side, and since tightening it, the drift is gone. I too originally thought it was merely a product of wide tires and road conditions, but when I had the wheels off for a thorough cleaning I discovered the loose bolt and tightened it. In the thousand plus miles since then I haven't felt the drift.
