If you replace the shoes, Is there a secret in replacing the spring on the clips? I must have cussed for 30 min. trying to get them on.
i used a ziptie in the center of the shoe, where the two little holes are, to secure the spring clip and notched a (V) in the end of a flat tip screwdriver to push each end of the spring clip into the retainers on the backing plate (hub)
