Help with Front Lowering Bolts
Old Apr 16, 2009 | 01:55 PM
IDM's Avatar
IDM
Default Help with Front Lowering Bolts
I have a set of new C6 and C5 front lowering bolts stock form with bushings untouched to play with.
Was wondering if I install the C6 bolts as they are and lower all the way what will happen compared to the c5 bolts lowered all the way?
What about cutting bushings on both?
thanks
Old Apr 16, 2009 | 03:02 PM
ALEXAMES's Avatar
ALEXAMES
The C6 bolts will go much lower than the C5 bolts. Do a search, I found TONS of great information on this topic. Just lowered mine using the ZIP kit.
Old Apr 16, 2009 | 04:31 PM
turbocrazy's Avatar
turbocrazy
I just purchased the zip kit as well. Appears to be a QUALITY buy for the money.
Old Apr 17, 2009 | 12:02 AM
IDM's Avatar
IDM
What does this Zip kit include?
any links?
How much lower is this kit doing the fronts? Is that with the c6 bolts?
Old Apr 17, 2009 | 12:15 AM
turbocrazy's Avatar
turbocrazy
http://www.zip-products.com/Zip/prod...9C2CF1CCF1C21B
Old Apr 17, 2009 | 01:50 PM
IDM's Avatar
IDM
someone tell me more about the c6 bolts.
I dont want to go that much lower than what the front stock bolts will do
I dont want to cut any bushings, can I just use the c6 bolts and lower all the way on those for a bit lower than the c5 bolts will do?
Old Apr 18, 2009 | 12:48 AM
IDM's Avatar
IDM
any ideas?
Old Apr 21, 2009 | 03:48 PM
IDM's Avatar
IDM
anyone?
Old Apr 21, 2009 | 04:02 PM
1SHADYZ's Avatar
1SHADYZ
I just cut my stock bolt bushings oof and got pretty low. How much lower could you get with the C6 Bolts b/c I heard the oppisite. Thanks.
Old Apr 23, 2009 | 04:00 AM
IDM's Avatar
IDM
Im also still wanting some final clarification on this
Old Apr 23, 2009 | 08:25 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
The front bolts will make no difference becasue you screw them down to lower, or you can cut the bushing or remove all together.
In order to lower the rear more, you need longer bolts becasue you raise the bolts to lower the car
Peace
Chip
__________________
..................Click for
Old Apr 23, 2009 | 10:49 AM
j84buick's Avatar
j84buick
The C6 bolts will lower your car about 3/8" more in the front then the stock C5 bolts. Most poeple just cut some of the bushing on the C5 bolt for the same effect.
If it's too low for you just go back and adjust the bolts again.
Old Apr 26, 2009 | 06:31 AM
IDM's Avatar
IDM
thanks this is the reply I was looking for.
I dont want to cut any bushings off, want a nice ride so I guess now I know to install the c6 bolts and tighten them all the way
Old Apr 26, 2009 | 06:39 AM
donsimpson12's Avatar
donsimpson12
Hello everyone...
I just need some help here.. These things sit so low to the ground now that that we typically have to be cautious of road bumps and uneven road now.. I understand that the lower you go, the wind resistance, MPG, and other things factor in to benefit overall.. But.. As I said, these things sit so low now that I have question why do this... ??? For show only or...??
Old Apr 26, 2009 | 07:18 AM
IDM's Avatar
IDM
just for looks, its not a daily driver once a month maybe
Old Apr 28, 2009 | 03:10 PM
IDM's Avatar
IDM
can another person verify this?
Old Apr 28, 2009 | 06:11 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
I put C6 bolts on the front of mine and only got about 1/4" more drop than originals turned all the way down. Not much difference at all.
Old Apr 28, 2009 | 07:41 PM
yyukon's Avatar
yyukon
Default Stock, Hardbar, C6 WCC Lowering Bolt
Thats sounds about right. The difference between a stock bolt and C6 lowering bolt is minimal. Go to link. Left to right Stock, Hardbar, and C6 WCC Lowering Bolt.
I am currently running the C6 WCC lowering bolts in mine.
http://forums.corvetteforum.com/memb...ar-c6-wcc.html
To Help with Front Lowering Bolts
