simple manual transmission question
Old Apr 16, 2009 | 02:30 PM
rocco666's Avatar
rocco666
Default simple manual transmission question
I know its in the manual but can someone tell me what type of transmission fluid to use in my 98 6 speed.
Old Apr 16, 2009 | 02:42 PM
Gideon's_Test's Avatar
Gideon's_Test
Dexron ATF
Old Apr 16, 2009 | 03:00 PM
Dave68's Avatar
Dave68
You might want to consider using synthetic ATF, like Amsoil universal ATF - better than the factory stuff and because you don't need to change it very often, the cost is insignificant. Don't forget the diff fluid as well.
Old Apr 16, 2009 | 03:01 PM
Oldvetter's Avatar
Oldvetter
Or if you want to use a synthetic, use Amsoil ATD (or their universal ATF). DO NOT use Mobil 1 ATF, it is NOT compatable with your paper blocker rings.
All C5's before 2001 had paper blocker rings.
Old Apr 16, 2009 | 03:05 PM
ericdwong's Avatar
ericdwong
I've had good luck with Royal Purple Synchromax- 98 M6 with 145k miles.
Old Apr 16, 2009 | 03:15 PM
rocco666's Avatar
rocco666
what diff fluid do i use,,,,,,
Old Apr 16, 2009 | 11:12 PM
itzza427's Avatar
itzza427
75 W 90(or 95) I used royal Purple in tranny and diff. RP syncro max in tranny,,Rp Max gear in rear. About 13,000 later still happy. The Max gear has the posi additive in it,,no need to add it!!
Old Apr 16, 2009 | 11:24 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I use RP 75w-90 in the diff - it has the additive already in it for the limited slip. I use RP Synchromax in the trans. Great stuff. Amsoil makes great products too.
Old Apr 17, 2009 | 03:20 AM
dbbspider's Avatar
dbbspider
Default tranny and diff fluid
Any dextron III ATF will do for the tranny. Although, I had a hard time finding Dextron III when I replaced mine at 65K miles. I guess Dextron III is no longer a spec. The stock fluid was still red when I dumped it. I replaced it with Castrol Domestic Multi vehicle ATF ($3 per quart) with no problems.
I also replaced my diff with Mobil 1, 75W-90 LS synthetic. Any Synthetic 75w-90 will work. Also, add limited slip additive.
Good luck
To simple manual transmission question
