[Z06] Radiator Screen?
Old Apr 18, 2009 | 01:36 AM
MTPZ06's Avatar
MTPZ06
Default Radiator Screen?
Anybody running the "protective radiator screen"? I've seen them vary from around $50 up to $100. What are the opinions on which models are the best to choose from? Is there any downside to installing one of these? Thanks.
Old Apr 18, 2009 | 02:15 AM
striper's Avatar
striper
You can get the same screen that many vendors use in the construction dept at Home Depot. $8 gets you enough material to make at least six screen kits. It's easy to make your own. Is it worth it? Absolutely, it keeps so much junk out of your radiator, leaves, etc.
Old Apr 18, 2009 | 06:59 AM
AU N EGL's Avatar
AU N EGL
Plus screens do not keep dirt and sand out, Still need to clean the radiator and AC condenser out at least once a year with an air hose
Old Apr 18, 2009 | 08:10 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Perhaps one of the highest "Corvette Tax" items, better to DYI! Maybe someone has a template?
Old Apr 18, 2009 | 01:32 PM
bob guzzy's Avatar
bob guzzy
I made one out of a peice of window screen I just used all the attaching points that were already on the car, fitting it behind existing panels.
A half hour and a few dollars worth of screen, my car was sucking up grass when I drove it thru my yard to the garage behind the house, it was one of those days when I had nothing to do, and some time to kill, I would never spend that much money on something like that.
Old Apr 18, 2009 | 01:46 PM
MTPZ06's Avatar
MTPZ06
Thanks for the insight everyone...sounds like a fairly easy DIY project. I've noticed some fairly reasonable ones on that auction site that already come cut to dimensions. Good to know that one isn't really better than the other.
Old Apr 19, 2009 | 10:23 AM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
I found that plenty of stuff would still make it through the screen,and then I would have to remove the screen to clean off the front of the radiator (no a/c). I sold the screen.
Old Apr 19, 2009 | 10:48 AM
AU N EGL's Avatar
AU N EGL
I made one out of 1/4" x 1/4" chicken wire. and use the screws that were already there
cost? $2 if that
To Radiator Screen?
