BSM removal Question
Old Apr 18, 2009 | 06:41 PM
grayfox2424's Avatar
grayfox2424
Default BSM removal Question
I started to remove my BSM and after taking off the front spear piece I was left with a black outline of the moulding and of course the adhesive...OK I can remove the adhesive but what do I do to remove the heavy black out line where the moulding was..Did any of you that removed the BSM have this situation...?? Help would be appreciated.
Old Apr 18, 2009 | 06:50 PM
GETOPLES's Avatar
GETOPLES
Old Apr 18, 2009 | 07:10 PM
blazer427X3's Avatar
blazer427X3
Maybe give claybar a shot and see if that takes it off.
Old Apr 18, 2009 | 07:21 PM
dobewillie's Avatar
dobewillie
try a fine polishing compound good luck
Old Apr 18, 2009 | 07:25 PM
3whit's Avatar
3whit
Default BSM Removal
If the car has had paint work it is best to leave them on .IMO
Old Apr 18, 2009 | 07:42 PM
MyOwn69's Avatar
MyOwn69
I'd try the following possibilities:
rubbing compound
swirl remover
polishing compound
goo-gone
WD-40
I took mine off and I was able to use some the listed to clean the side and it all looked good!
Old Apr 18, 2009 | 07:59 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
I just got in from doing mine and same thing here. I was able to get most of it off with a clay bar. I got some of that goo gone gel think I'm going to go back out and let it soak on longer? Let me know what works for you.
Old Apr 18, 2009 | 11:50 PM
AUandAG's Avatar
AUandAG
I removed mine yesterday. Only took me 8+ years! Just like getting a new car. All black stains came off easily with polishing compound. Goo Gone and WD-40 couldn't touch them.
Old Apr 19, 2009 | 11:02 AM
GETOPLES's Avatar
GETOPLES
When you guys say a "polishing compound" what does that mean exactly?
Old Apr 19, 2009 | 11:03 AM
tommie's Avatar
tommie
clay bar got my paint cleaned up after the adhesive was removed
Old Apr 19, 2009 | 11:14 AM
grayfox2424
Thanks guys..I'll try the ClayBar route.
Old Apr 19, 2009 | 12:07 PM
Dominic Toretto's Avatar
Dominic Toretto
How does a claybar work? And what exactly does it do?
-Alex
Old Apr 19, 2009 | 12:10 PM
Jet-Jock's Avatar
Jet-Jock
Can you post a pic?
Old Apr 19, 2009 | 05:30 PM
tlc0706's Avatar
tlc0706
-Alex
The clay kits are sold by several companies. Basically it's a soft clay designed for paint cleaning with a lubricant spray. Wording on small areas: Spray the lube...rub the clay back and forth on the area (if it sticks-spray more lube) Then turn the clay over and look at the junk it picked up....It's amazing......Clean with microfiber towel....Wax Twice a year
BTW: Knead the clay between panels
Enjoy
Tom
Old Apr 20, 2009 | 01:21 AM
AUandAG's Avatar
AUandAG
Polishing compound is similar to "rubbing compound" only less abrasive. According to the labels, ...."easily removes light scratches, light to medium oxidation & swirl marks"
Old Apr 20, 2009 | 07:54 AM
Jet-Jock's Avatar
Jet-Jock
I would not use rubbing compound. Try heating it with a hair dryer and rolling off the residual with your finger. If 3M adhesive cleaner (red spray can) or googone doesn't work, then try some 3M Perfect-It II (39009), which is a less abrasive polish/swirl mark remover (found at most auto parts stores).
Old Apr 20, 2009 | 01:04 PM
BigTattooMan
St. Jude Donor '10
Just got the rest of mine off. After getting most of it off with the clay bar I was able to get the last of the line off with Meguiars cleaner wax. Good luck guys...
Old Apr 20, 2009 | 07:59 PM
grayfox2424
I found the black stripe absolutely impossible to remove...the thought of having to do two doors and another spear was too much foer me ..so I replaced the spear i had removed and called it a day. ( Besides from the condition of the BSM on the door it appears it has done much to protect the basic door from several dings ).
To BSM removal Question
