Computer Reset
Old Apr 21, 2009 | 04:16 PM
kozmo's Avatar
kozmo
6th Gear
Default Computer Reset
My battery is totally dead. Won't even jump start. What have I lost as far ar the computer is concerned? Have I just lost radio, seat, mirror, steering settings? My friend told me all the drive/engine computer settings would reset themselves after driving for 50 miles or so? Is there anything that I will need to take into the dealer for or should I be fine? Thanks.
Old Apr 21, 2009 | 05:00 PM
TopFuelTim's Avatar
TopFuelTim
Default Shouldn't be an issue
I removed my battery from my Y2K coupe, to do some diagnosing on my Monte Carlo. Had it out about half an hour.
I think the only thing I had to reset was the clock on the radio. I do remember not having any problems.
Tim Glover
Old Apr 21, 2009 | 05:09 PM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
GM advises disconnecting the battery if you aren't going to drive it for 25 days or so (to avoid a dead battery). So, there is no problem from no current to all the computers other than the clock and maybe radio presets.
Old Apr 21, 2009 | 05:29 PM
SUPERCRUZ's Avatar
SUPERCRUZ
No problems. Just install the new battery and reset your radio, clock, and seats. Start the car up and drive it. It will re-learn everything it needs to operate.
Old Apr 21, 2009 | 05:44 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
all I lost was the clock. did have to re-sync both fobs. radio presets and seat memory remained intact
Old Apr 21, 2009 | 05:51 PM
kozmo's Avatar
kozmo
6th Gear
Thanks alot. Is this battery on the shelf at most auto parts stores or is it special order?
Old Apr 21, 2009 | 07:17 PM
Jet-Jock's Avatar
Jet-Jock
In theory you should only lose the HUD settings, they will go back to default.
You may need to drive it a few miles for the TPS monitors to recalibrate, I've seen those values sit at 0 psi for a half dozen miles then come back alive.
Old Apr 21, 2009 | 07:22 PM
Jet-Jock's Avatar
Jet-Jock
AC Delco 75P-7YR $85. 3 year free replacement.
Old Apr 21, 2009 | 08:25 PM
8VETTE7's Avatar
8VETTE7
Other than what has been mentioned above the only thing you might find messy is if you have the THEFT LOCK radio in the car. Should be something on the radio face plate or a plate on the dash that says THEFT LOCK. Even with that radio unless someone set the pass code for the radio you won't have a problem. If the radio is a problem the Stealer will want a fortune to unlock it. Do a search on the Forum and there was a recent thread about how to get it unlocked........
To Computer Reset
