mixing tires question
Old Apr 23, 2009 | 03:08 AM
LT1driver's Avatar
LT1driver
Default mixing tires question
front stock size runflats (GY) and rear stock size non runflats (wideovals) what could I expect....safety, handling, highway driving, town driving......this is not a permanent thing just trying to use up some good front tires before buying new firestone ovals to match rears. thanks.
Old Apr 23, 2009 | 06:04 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
When I bought my tires, I asked the same question. The tire experts told me that mixing the tires would cause the non run-flat tire to run hotter. Not sure why, but that is what they said.
Old Apr 23, 2009 | 09:29 AM
jrose7004's Avatar
jrose7004
I just never like to mix tires.
Old Apr 23, 2009 | 10:08 AM
Gideon's_Test's Avatar
Gideon's_Test
When I bought mine, it had the Firestone run-flats on the front and Kumho non-runflats on the rear. While I know it's not ideal, it's been a year and a half now and haven't had any problems.
Old Apr 23, 2009 | 10:15 AM
8VETTE7's Avatar
8VETTE7
I have had the GoodYear RunCraps on the front and Michelin PS2's on the rear for about 10 months and no issues. When the Run Craps get a little more worn I'll put the PS2's on the front as well. Didn't have the $$$ for all 4 Michelins when I put them on the rear plus the RunCraps still had meat left on them............ As always YMMV
Old Apr 24, 2009 | 01:17 AM
LT1driver's Avatar
LT1driver
thanks for the imputs I don't like to mix either but wanted to be sure no major safety issues etc.
Old Apr 24, 2009 | 01:42 AM
DeeGee's Avatar
DeeGee
The stock runflats have a very stiff sidewall. Wideovals non RF are much softer and more flexible
You'd have a stiffer front end and a softer rear end which on a high performance rear wheel drive car I'd say isn't a good idea.
I doubt its a safety issue if you run matched pairs at highway speeds. I'm sure AH will compensate in all but the hardest manoeuvering. However, it has to degrade the handling somewhat.
I wouldn't do it personally. JMHO
To mixing tires question
