C5 Temperature Problem
Old Apr 24, 2009 | 06:40 PM
Mixxit's Avatar
Mixxit
Default C5 Temperature Problem
On the way home today my coolant temp reached 230 degrees. It didn't seem to want to go any higher than that but that's definitely about 20 degrees higher than usual. I first glanced at my temp gauge when I caught a slight smell of anti-freeze. I checked under the hood and there doesn't appear to be any leaks. My heater didn't seem quite as hot either. Today was a warm day (about 81 degrees) but even it 100 plus heat, it usually doesn't go above about 220.
What could it be? Thermostat? Low coolant? Heater core (let's hope not)?
Thoughts? Thanks for any insight.
Old Apr 24, 2009 | 07:12 PM
ToplessBlonde's Avatar
ToplessBlonde
I had a similar problem. Was a thermostat issue
Old Apr 24, 2009 | 07:22 PM
dobewillie's Avatar
dobewillie
good luck finding a solution
Old Apr 24, 2009 | 08:09 PM
Mixxit's Avatar
Mixxit
That's my first guess too but knowing my luck with cooling systems...
Old Apr 24, 2009 | 09:11 PM
Mike Yeager@Eastcoast Performance's Avatar
0Mike Yeager@Eastcoast Performance
Former Vendor
Hi, there are a few things to check out. 1st, Do you have a 160 degree thermostat? If not you need one. 2, Check for trash, leaves and whatever between the radiator and ac condensor, clean all that out.
3rd, make sure the center airdam is function properly. 4th, when is the last time you had the system flushed?
If you would like to call me directly please do, we help people out all over the US from the Corvette Forum (Parts-Service) what ever you need. Just ask for Mike or Joey
Mike Yeager
Eastcoast Performance & Corvette
1-864-404-1776
Old Apr 25, 2009 | 03:54 AM
Mixxit's Avatar
Mixxit
Thanks Mike. Thanks for the info!
There is no debris between the radiator and AC.
How do I know if I have a 160 degree thermostat?
I got the C5 used and I have never changed the coolant but I don't know if the previous owner did.
How would I know if the center air dam is functioning properly? It appears to be connected properly and such. Any other tests?
Sorry for all of the questions! Thanks for any other suggestions!
Old Apr 25, 2009 | 10:03 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Have you checked to see if the fans were running? Yes, both always run as needed.
Old Apr 25, 2009 | 11:08 AM
Mixxit's Avatar
Mixxit
They were. When I got home the coolant temp was about 225 so the fans were on low-speed.
Old Apr 25, 2009 | 11:36 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Sounds like your thermostat is stuck in the OPEN position.
When it sticks open, coolant runs through the system too fast and doesn't spend enough time in the radiator. So it isn't cooled sufficiently.
Old Apr 25, 2009 | 01:43 PM
Mixxit's Avatar
Mixxit
Thanks. That's what I'm thinkin' too.
I've seen serveral posts on WHICH thermostat to buy but does anyone have a how-to on how to change it? It looks pretty simple but I just want to make sure there's nothing wacky that I'm missing. I'd definitely prefer not to drain the coolant too.
Old Apr 26, 2009 | 06:31 PM
Former Vendor
It was very nice talking with you Saturday on the phone, its alot easier to explain things verbaly for me anyway. Did you check your fans to make sure they both come on at around 212.
If they did not both come on check all the connections 1st.
Call me Monday if you want the HP 160 thermostat.
Mike Yeager
1-864-404-1776
Old Apr 26, 2009 | 09:21 PM
Vettman 1's Avatar
Vettman 1
Had exactly the same symptoms! I replaced the thermostat and the temp. sensor ($14.00 located over #1 plug). Everythings normal again. Don't know which was at fault, but I suspect the thermostat.
Old Apr 27, 2009 | 03:43 PM
Mixxit's Avatar
Mixxit
Mike Yeager
1-864-404-1776
Hey Mike! Wish I could say the same but I didn't call you!
Someone must have piggybacked my thread. Anywho, I'm still trying to decide if it's a problem. I took her out on Saturday and the temp never got over 215.
All that's to say, I still might call ya and if I need a new stat, I'll be getting a 160 from you.
Thanks for the help that you provide everyone here.
Old Apr 27, 2009 | 04:36 PM
Oldvetter's Avatar
Oldvetter
I see no problem, see below:
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
BUT, always check for debris in front of radiator when having cooling problems, these C5's are bottom breathers and act like street vacuum cleaners (leaves, plastic bags, etc)
To C5 Temperature Problem
