GM recall-Column Lock
Old Apr 27, 2009 | 08:22 PM
Dale96's Avatar
Dale96
Default GM recall-Column Lock
Can someone tell me the GM recall # for the recall where they removed the lock plate-My shop says they didn't remove the lock plate-I believe they're wrong.
Old Apr 27, 2009 | 08:25 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
My local GM dealer did mine, it was No: 04006
Lock plate was removed.
Old Apr 27, 2009 | 08:33 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
http://forums.corvetteforum.com/1567869864-post382.html
http://www.c5registry.com/Technical/clrecall/index.htm
Old Apr 27, 2009 | 08:43 PM
34RedRage's Avatar
34RedRage
my lock plate was also removed by the dealer, your guy doesnt know what he is talking about.
Old Apr 27, 2009 | 08:50 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
they did mine to, then 3 years later it locked up
Old Apr 27, 2009 | 09:02 PM
jrose7004's Avatar
jrose7004
Mine was removed on the 98 I used to have too.
Old Apr 27, 2009 | 09:38 PM
83Camaro's Avatar
83Camaro
my relay failed, so i took it to the dealer, they warrenty all parts including recall items for only 12 months. Youd think if it was important enough to be a SAFETY recall and to bring your car in and fix for free theyd want to KEEP it fixed, but once they figure they did it once who cares what happens after that attitude. The dealership is such a peice of ****, they dont give a **** all they want is your money, worst service EVER.
Old Apr 27, 2009 | 10:32 PM
redrckt97's Avatar
redrckt97
mine was removed last year - 4006C was the code
Old Apr 28, 2009 | 07:12 AM
dougbfresh's Avatar
dougbfresh
Why do people keep BEATING THIS DEAD HORSE. GM can't fix this problem-never could. If you don't fix it YOURSELF-it won't get fixed-PERIOD.
Old Apr 28, 2009 | 01:35 PM
blacksedan87's Avatar
blacksedan87
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I installed the COH CLB on my '98 Pace Car. The column is now unlocked permanently, and I can turn the steering wheel freely without the key. But after I installed the CLB - I am now receiving the "PULL KEY-WAIT 10 SECS" message every time I start the car.
Per COH's instructions, I pulled the #23 and the #25 fuse. I also pulled the #29 fuse. I have had our tuner go into the PCM with HP Tuners and set the fuel shutoff parameter to 255mph (which is the max), so at least now the fuel doesn't shut off. The car does not have the "K" harness or the relay.
I tried a second CLB that is brand new and the stupid message still appears. If I turn the key on, wait a few seconds, the message appears - and then I turn off the key, pull it out and then I restart...all is well. How do I get the message to not appear - what I have I missed?
It's not an issue of affecting the operation of the car - it's simply an inconvenience having the message on the DIC that a reset will not clear. I usually subscribe to the philosophy "If it ain't broke, don't fix it", but I thought I was avoiding an issue by installing the kit - instead I have created an issue when I didn't have one.
Old Apr 28, 2009 | 02:38 PM
blacksedan87
Originally Posted by 8VETTE7
Randy,
Look through the procedure in the following link. I'm willing to bet it can correct your error messages:
http://forums.corvetteforum.com/c5-t...st-me-0-a.html
If you do try the procedure please post your results.
On a side note, does you shop use the HP Tuners on tunes? I may be interested in talking to you about a few things I would like done to my 04.
Chuck S. AKA 8VETTE7
Thanks for the info, Chuck. I printed out the post from ROCK N ROLL and I'm going to give to our guys in the shop to see what they think. After they try it - I'll post up the results....yea or nea!
As far as tuning software - yes we use HP Tuners to tune in our shop. We have a Dyno-Jet in the shop - a tune includes normally about three pulls plus a driveability tune.
Please give me a call - I'd be happy to talk with you about your needs!
Old May 14, 2009 | 11:26 AM
blacksedan87
As I promised - here's an update on the CLB issue that I'm having with the '98 Pace Car. I had Cody - our lead tech follow the instructions on RocknRoll's post about cleaning up the grounds on G201 and G202.
Cody told me that they were both pretty clean and tight, but he took the connectors off anyway, sanded down the connection point to assure good ground, and reassembled the connections.....this morning the "PULL KEY & WAIT 10 SECS" message appeared at start up.
So now, I'm at a loss as to what to try next.....anyone have any suggestions?
Old May 14, 2009 | 12:30 PM
blacksedan87
The Pace Car is an MN6 - so I will show this to Cody and see what he thinks. Thanks for the help - Chuck! I'll keep you posted.
BTW - are you still looking for a tune?
Old May 14, 2009 | 02:12 PM
blacksedan87
Check your PM's in a few minutes....
Sorry about not knowing the Pace cars were manual. I knew FRC's and of course Z's are manual and now I know Pace cars also.
Not all Pace Cars were manual, only 547 out of 1163. Mine happens to be a manual!
Old May 14, 2009 | 07:01 PM
oldvetteguy99's Avatar
oldvetteguy99
My recall was done in 2001 and just went through the hassel of the steering column lock service DIC notice that shut my fuel off. Had it towed to my repair shop and had the CLB installed for $85 plus the CLB cost. What a deal.
To GM recall-Column Lock
