GM Differential Fluid
Old Apr 27, 2009 | 08:53 PM
rkink's Avatar
rkink
Default GM Differential Fluid
I'm getting ready to change the diff fluid shortly and called up my local dealer to see if he had the GM # 12378261 synthetic fluid as indicated in the owners manual. He says this has been replaced by # 89021677, also a synthetic. When I asked about the limited slip additive # 1052538, he says this is not required with the 89021677. I think he is wrong. Can someone verify?
Old Apr 27, 2009 | 09:30 PM
itzza427's Avatar
itzza427
It may already be in there. I used Royal Purple Max Gear,,and it has the limited slip additive already in it!!
Old Apr 27, 2009 | 09:43 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Gene culley (gmpartshouse) hooked me up with the new stuff that is being used in the c6's. The friction modifier is in it, and the price was right!
Old May 1, 2009 | 06:31 PM
robsc501's Avatar
robsc501
Hi There:
Did a google search gm 12378261 was replaced by 89021677 which as a earlier poster stated contains the modifier.
robsc501
Old May 1, 2009 | 06:52 PM
I Owned U's Avatar
I Owned U
So if I go buy 2 quarts of the new fluid (89021677), I dont need to buy the LSD additive (1052358) from GM as well?
Old May 1, 2009 | 07:03 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Many new fluids these days do NOT require the additive. He's probably correct.
Old May 1, 2009 | 09:38 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Old May 1, 2009 | 11:18 PM
rkink's Avatar
rkink
So is the 89021677 the new Dexron fluid the dealerships are recommending for the C6's? If so, it is my understanding that the C6 fluid should not be used in C5's?
To GM Differential Fluid
