spray paint vendor?
Old May 1, 2009 | 02:47 PM
Indy's Avatar
Indy
Default spray paint vendor?
Who sells original spray paint (Nassau blue)? My local auto stores don't seem to carry it...
Old May 1, 2009 | 02:53 PM
4U2ENVY's Avatar
4U2ENVY
From: Obama says I'm a bitter white guy clinging to my guns and religon and he's right
Try this site.
http://www.automotivetouchup.com/
Old May 1, 2009 | 03:03 PM
j84buick's Avatar
j84buick
That may be tough. I found Torch Red from Duplicolor at my local store. They didn't make nearly as many C5s in Nassau blue so probably not as much demand. Someone has to make it though!
Old May 1, 2009 | 03:53 PM
Charliec's Avatar
Charliec
Try a automotive paint supply. I gave them the code and they mixed it and put it in a spray can for me.
Old May 1, 2009 | 04:02 PM
travelingypsye's Avatar
travelingypsye
I got mine from expresspaint.com. Matched perfect & very easy to use. They don't mix it until you order it....... Self leveling just in case you overspray.....
Old May 1, 2009 | 05:08 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
That looks like great stuff. Paintscratch.com is another option I have used with great success.
Old May 1, 2009 | 05:48 PM
bucklidl's Avatar
bucklidl
you could try paintscratch,com they have a really good selection.
Old May 1, 2009 | 06:01 PM
Indy's Avatar
Indy
So would 23/WA348D Bright Blue Metallic be the correct paint?
Old May 1, 2009 | 06:15 PM
travelingypsye
I do believe that is the ticket...
Old May 1, 2009 | 06:34 PM
3whit's Avatar
3whit
Expresspaint.com They will advise you on how to locate your paint code and then set you up with perfect match Base coat / clear coat or just single stage . I Used them for Pewter Metallic and it is perfect ..
Old May 1, 2009 | 09:54 PM
geluna21's Avatar
geluna21
How'd you get your covers so smooth? Does the paint fade being under the hood cause of the heat?
Old May 1, 2009 | 10:28 PM
canyon lake corvette's Avatar
kudos to this guy and expresspaint , I used there paint and it worked very well, the magnetic red matched perfect, which is a tri coat paint.
Old May 1, 2009 | 11:23 PM
travelingypsye
I used an orbiter sander with 300 grit wet/dry. Then primed it with scratch filler primer (wally world or any auto store) & resanded by hand with 400 under water so to see any ruff spots. After 5+ coats of primer (sanding in between) They were ready for color. The nassau blue is mine & the green is what I did for a couple of bucks.
No signs of fading after 3 years.
Old May 1, 2009 | 11:25 PM
travelingypsye
Thanks. I love seeing & hearing about a DIY job.
To spray paint vendor?
