[Z06] Nitrogen vs Air
Old May 1, 2009 | 10:53 PM
pcbunn's Avatar
pcbunn
Default Nitrogen vs Air
What's up with the nitrogen vs air debate? Cosco wants to put nitrogen in my new Michelins and charge me for it but I read in Car & Driver that you shouldn't mix air with the nitrogen. So how do I add air to keep the pressure correct using my air compressor? My Z never sees the tract or especially high speeds. Is this just a fad or what? I've been putting compressed air in my Z since '01 with no effects that I've noticed. Somehow I think some desk jockey has just dreamed this up!
Old May 2, 2009 | 12:25 AM
mikeetran's Avatar
mikeetran
I work at a tire store, and so I am supposed to be "pro-nitrogen." Most places that offer nitrogen fill will also offer nitrogen "top-offs" to maintain proper tire pressure. The idea behind nitro is that the molecules are supposed to be bigger than "air" molecules and are less prone to pressure changes by temperature changes.
Based on my experience, nitrogen filled tires will lose pressure just as fast and often as regular air. Atmospheric air, if I remember correctly, is approximately 70 percent nitrogen anyway. I have run nitro in my 02 Z06 before, with neither positive or negative results.
Old May 2, 2009 | 12:40 AM
cheetah45's Avatar
cheetah45
Air is 78% nitrogen. A shop that is hyping nitrogen is doing so to pad their profit margins bigtime.
Old May 2, 2009 | 03:21 AM
rustyguns's Avatar
rustyguns
i am not sure but wife's car gets nitro in her tires and it seems i have to add air to my non nitro tires more often then her
Old May 2, 2009 | 03:58 AM
James92's Avatar
James92
nitrogen molecules are larger and don't leak as fast as air. also, nitrogen doesn't have any moisture so it doesn't corrode your wheels.
Old May 2, 2009 | 09:05 AM
AU N EGL's Avatar
AU N EGL
nitrogen or N2 contains less moisture then normal air. tire temperature fluctuation are marginal at best when using Nitrogen.
is N2 needed for passenger cars? IMO NO. for race cars? YES most definitively
Old May 2, 2009 | 10:05 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Old May 2, 2009 | 10:18 AM
Atok's Avatar
Atok
My job is to know a thing or two about tires. Two things...
1. Pure nitrogen out of a bottle contains no water vapor. Air does. Water vapor has a high expansion ratio so if it's inside your tires when they get warm the pressure will build more. Does this apply to a street tire? NO!! It's used in racing because tire temperatures get quite high so it makes sense there. It helps control the pressure build-up in race tires and therefore the tire's spring rate. Street use... just trying to rip ya off.
2. Air contains oxygen which over time will oxidize rubber causing it to harden, weaken, and crack. Filling the tires with pure nitrogen reduces the amount of oxygen migration in the tire which makes the carcasse last longer. Does this apply to passenger car tires? NO!! Yeah the theory is true but you'll never run your tires long enough for oxidation to become a problem. It does apply to big rig tires because they are recapped multiple times so carcasse life is important. They may have a couple million miles on the carcasse before it's scrapped.
In summary, you're wasting your money by using nitrogen unless you drive a semi-truck. Just a total sales farce. Save your money.
Old May 2, 2009 | 10:38 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I ran nitro filled tires last Mon/Tue at Watkins Glen, and I was pretty amazed by the fact that the air increase after every session was exactly the same. Front left/back to front, all of the tires gained exactly 10lbs. Normally, I'd adjust pressure after every session with air.
Old May 2, 2009 | 06:40 PM
rustyguns's Avatar
rustyguns
so the air pressure increase was the same but between races you did not have to adjust....this is better its always a gusseing game with daytime and track surface temps changing throught out the day. i have to adjust and hope
Old May 2, 2009 | 06:53 PM
tonyjp's Avatar
tonyjp
It is worth using. As others have said it gets H2O out of the air and removes most of the other gasses that are not nitrogen. In Colorado we may get a foot of snow and be 60 degrees the next day. All newer cars have tpms. With nitrogen your light will be on a lot less. The truth about nitrogen for passenger vehicles is probably somewhere in the middle of the two sides of the argument. It has no negative effects and some positive ones.
Old May 2, 2009 | 07:17 PM
Iowa_Z06's Avatar
Iowa_Z06
You can probably run N2 in a passenger car, but it ain't worth the effort. The only folks who should run N2 are racers. As the tires heat during a race the N2 won't expand as much, so you can better control your air pressure during the race. In a race with the vehicle and tires at it's limit, slight unexpected variations in tire pressure can dramatically affect how the car handles, and may render it unmanageable (i.e. unmanageable under-steer/over-steer).
Yes, I think it's just a way to bilk customers for more money.
Old May 2, 2009 | 09:42 PM
rustyguns's Avatar
rustyguns
N2 is free at Costco
Old May 2, 2009 | 09:51 PM
pcbunn's Avatar
pcbunn
You're correct. I checked the quote and its free with lifetime checkups. It was BigBrand that charges $2.00 per wheel. I'm OK with using it but just wondered if it made any difference. Thanks to all who replied as I learned a lot about the issue.
Old May 2, 2009 | 10:38 PM
GeorgeZNJ's Avatar
GeorgeZNJ
Thanks, didn't know that.
Old May 3, 2009 | 01:26 AM
backnblack2003z06's Avatar
backnblack2003z06
We had the rep come in the dealer I work at and try to sell us the Nitrogen machine, I got him to demo it on my Trailblazer SS and another tech got it done on his Z51 Silverado. It does seem to keep the pressures a little more stable, and I noticed the ride was a tiny bit "rougher", I thought that might be in my head until the other tech mentioned the same thing to me. Bottom line I wouldn't pay for it but if its free it can't hurt. We ended up not getting the machine.
To Nitrogen vs Air
