Dtc po137
Got my vert out yesterday and twice got the check engine light with the PO137 code. The code reader I have says low voltage bank 1 sensor 2. I've been getting this code for a while now and usually just clear it. But I'm tired of doing that and want to fix it. Is this a matter of just replacing the oxygen sensor on the drivers side behind the cat or is there something else that causes this code that I should look for? I hate to replace parts and still have the same problem pop up again later. I can sometimes go for weeks with out it doing this and then other times it will do it mulitple times the same day.
Thanks for any ideas
Bob
