help - trans fluid change problem
Old May 3, 2009 | 12:55 PM
mistermog's Avatar
mistermog
Default help - trans fluid change problem
Hi guys, I am attempting to change the trans fluid on my 00 mn6.
I drained it no problem but now the issue is with filling it back up.
I put in just under 4 quarts and can not feel any fluid, so i figure i will just add more until it starts to spill out of the fill hole.
Well, I put in another quart and still nothing. what gives, 5 quarts?
if i start the engine of course it pours out, but as soon as i turn it off, it stops.
now i have no idea how much is in the car, and i dont know what to do here... how much should really be added until it starts flowing out?
am i going crazy here?
Old May 3, 2009 | 12:56 PM
slothy's Avatar
slothy
where are u filling it at?
Old May 3, 2009 | 01:00 PM
mistermog's Avatar
mistermog
the sensor hole by the sticker that says dexron on the passenger side... the standard fill hole from what ive found.
Old May 3, 2009 | 01:01 PM
slothy's Avatar
slothy
there? when i did mine it was under 4 quarts
Old May 3, 2009 | 01:05 PM
mistermog's Avatar
mistermog
um.... i have a 22mm sensor that i took out as the fill hole, my drain hole has the 3/8 drive.
the place i am using is on the pass. side, about halfway up, with an electrical connector and 2 metal prongs sticking out in front of the hole.
shoot am i using the wrong hole?
Old May 3, 2009 | 01:07 PM
slothy's Avatar
slothy
mine had a sensor there also - but like i said i was about 3.5 quarts if that before it started to drip out
Old May 3, 2009 | 01:13 PM
mistermog's Avatar
mistermog
so which side did you drip from, the sensor or the hole onthe driver side?
i just took off that plug on teh driver side and i got a rush of fluid, and its sitting just under the driver side hole now. (which is obviously lower on the tranny than the sensor on the passenger side hole)
Old May 3, 2009 | 01:18 PM
slothy's Avatar
slothy
my trans is diff then yours (mn12) - so prob why i have a sensor there and u have a plug - i think mine was driver side - did it last year so don't remember off hand.
Old May 3, 2009 | 01:21 PM
mistermog's Avatar
mistermog
i thought the transeses were the same other than gear ratios?
hmmm well, that might make sense, i didnt think there was a difference, but i guess there is. oh well, its sitting at the fill hole mark on the mn6, so i should be good. ill go take it for a spin and see what happens.
Old May 3, 2009 | 08:27 PM
Fire 22's Avatar
Fire 22
I did mine about a month ago, I have the mn6 in my 01. The fill hole I used is on the drivers side just above the sticker, its a 3/8" drive plug and I put in just under 3 quarts.
Old May 3, 2009 | 08:30 PM
mistermog's Avatar
mistermog
Well like i said this afternoon i uncorked that fill hole and about 1/2 a quart came out, and I drove it around about 150 miles today and everything seems to be working fine.
I guess I just had the wrong spot... I was reading something for the mn12.
Old May 3, 2009 | 08:45 PM
Patches's Avatar
Patches
You were filling at the wrong location. The fill plug/hole is on the driver's side as pictured below by Fire 22. That's why you had to add more than normally required - should have been just short of 3 qts. The only manual tranny with the temp sensor in the driver-side fill hole is the M12 in the Z06. You should recheck for the fill hole on the driver's side and fill to the correct level.
Originally Posted by Fire 22
Old May 3, 2009 | 08:48 PM
mistermog's Avatar
mistermog
Hey patches, yeah we figured that out, i was reading instructions for the Z and i think we got it all straightened out
so far everything seemed fine, but the new mobil 1 fluid doesnt feel any different than the 70k mile redline i took out.
Old May 3, 2009 | 09:00 PM
Patches's Avatar
Patches
Not surprising as the manual tranny fluid doesn't reqire changing at all according to the maintenance section of the service manual so, if your tranny was operating smoothly, a fluid change may be hard to notice in terms of feel. Many here do it for peace-of-mind or to try and resolve tranny issues.
Old May 3, 2009 | 09:02 PM
mistermog's Avatar
mistermog
I have trouble getting into 2nd and reverse, so i figure it would be an easy way to tell if my forks are bent.
that i havent seen how to fix yet, but i havent really looked all that much yet.
To help - trans fluid change problem
