tire size!!! need help!!!
Old May 3, 2009 | 08:33 PM
black*out*vette's Avatar
black*out*vette
Default tire size!!! need help!!!
will 335/30/19's fit under a stock c5 vette. i now have 315/30/19's on there.. any advice would be appreciated thanks!!!
Old May 3, 2009 | 08:38 PM
waktasz's Avatar
waktasz
Well, do you have 1cm of clearance on either side of your current setup?
Old May 3, 2009 | 08:43 PM
black*out*vette
well i looked on the nitto website and the tires i have now are 12.36 inches wide and the 335's are 13.31 inches wide
Old May 4, 2009 | 03:18 AM
JETZ's Avatar
JETZ
You said 'under', not sticking out right?
What width are your wheels? 335's require 12-13'' wheels.
Depending on your offset, you will need a tub, or L5 flares with a spacer.
Old May 4, 2009 | 04:12 AM
2000lambovette's Avatar
2000lambovette
It can also depend on the tire brand. In a perfect world all 335 tires would be the same width and use the same width wheels. If you check tire rack .com you can check specs on most brand tires and they will have the actual width and reccomended wheel size. Becasue not all 335 or 315s are the same width or use the same size wheel.
To tire size!!! need help!!!
