Left Headlight Stays up
Old May 4, 2009 | 09:47 PM
Brian's Avatar
Brian
Default Left Headlight Stays up
I've had this before and read all the available posts related to it. I added the washers to shim out the motor. and it seemed to work ok. I bought new bumpers. Why does it keep popping up and what can I do now?
Old May 4, 2009 | 10:24 PM
Jet-Jock's Avatar
Jet-Jock
What do you mean popping up?
What's this about shims and washers? What problem were you trying to fix to begin with?
Old May 4, 2009 | 10:28 PM
Brian's Avatar
Brian
Left headlight stays up. Shut lights off - it goes down and then pops right back up again.
Old May 4, 2009 | 10:58 PM
Jet-Jock's Avatar
Jet-Jock
Ok, understanding the linkage is the motor continuing to operate while it returns to the up position?
What work was previously done on it? Was this problem happening which is why work was done or for another problem?
Old May 4, 2009 | 11:53 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Does it Attempt to go down again or lock in the "up" position?
Old May 5, 2009 | 01:43 AM
DeeGee's Avatar
DeeGee
If you did the TSB fix and replaced the bumpers I'd now be thinking a gear change or motor swap.
Old May 5, 2009 | 05:30 PM
Brian's Avatar
Brian
Light retracts and goes back up. New metal gear was installed two years ago. Motor you think?
Previous work included shimming the motor with washers, new bumpers and the gear change (plastic one was stripped).
Old May 5, 2009 | 05:43 PM
ecoman's Avatar
ecoman
Mine was just doing the same thing turned over nylon stop bushing in lower part of housing and that fixed it. at first i only saw the white stop on the top but it was the lower one that had the problem.
hope this helps
Old May 6, 2009 | 01:13 PM
DeeGee's Avatar
DeeGee
Does this help any. Thats a tough one
Document ID# 661511
2002 Chevrolet Corvette
________________________________________
Headlamp Door(s) Inoperative
Step Action Yes No
Schematic Reference: Headlight Doors Schematics
1 Did you perform the Diagnostic System Check? Go to Step 2
Go to Diagnostic System Check - Lighting Systems
2 Turn the headlamps ON and OFF.
Do the headlamp doors open and close? Go to Testing for Intermittent and Poor Connections in Wiring Systems
Go to Step 3
3 Is only one headlamp door inoperative?
Go to Step 9
Go to Step 4
4 Are the headlamp doors closed at all times?
Go to Step 5
Go to Step 7
5
1. Remove the right hand headlamp assembly.
2. Disconnect the control module connectors C1 and C2 to the actuator for the headlamp opening door.
3. Turn the headlamps ON.
4. Connect a test lamp between the headlamps ON input circuit and a known good ground at connector C1. Refer to Circuit Testing in Wiring Systems.
Does the test lamp illuminate?
Go to Step 6
Go to Step 13
6 Connect a test lamp between the headlamps ON input circuit and the ground circuit of connector C1.
Go to Step 11
Go to Step 14
7
1. Turn OFF the headlamp switch.
2. Disconnect the actuator control module to the headlamp opening door.
3. Using a test lamp, probe between the headlamp OFF input circuit and ground.
Go to Step 8
Go to Step 11
8
1. Disconnect connector C209.
2. Using a test lamp, probe between the headlamp OFF input circuit (female side) and ground.
Go to Step 12
Go to Step 15
9 Test the power and ground circuit of the headlamp door control for a poor connection or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 19
Go to Step 10
10 Inspect the harness connector for headlamp opening door assembly for a poor connection. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and complete the repair?
Go to Step 19
Go to Step 16
11 Inspect the harness connector for headlamp opening door actuator control module for a poor connection. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 19
Go to Step 17
12 Inspect the harness connector for multifunction turn signal lever for a poor connection. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 19
Go to Step 18
13 Repair a poor connector or an open in the headlamp ON input circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 19
14 Repair a poor connector or an open in the ground circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 19
15 Repair a short to battery positive voltage in the headlamps OFF input circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 19
16 Replace the headlamp opening door assembly. Refer to Headlamp Opening Door Replacement .
Did you complete the replacement?
Go to Step 19
17 Replace the control module for the headlamp opening door actuator. Refer to Headlamp Control Module Replacement .
Go to Step 19
18 Replace the multifunction turn signal lever. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Go to Step 19
19 Operate the system in order to verify the repair.
Did you correct the condition? System OK
Go to Step 2
Document ID# 661511
Old May 6, 2009 | 01:50 PM
Jet-Jock's Avatar
Jet-Jock
That is the Troubleshooting table from the FSM. Excellent one note to keep in mind, the first answer "Go to..." is for a YES answer and the second "Go to...." is for a NO answer.
So picking up at 6 for example, if YES Go to step 11 if NO then Go to step 14. So on and so forth.
This will isolate the electrical problem.
Old May 10, 2009 | 08:39 PM
Brian's Avatar
Brian
That troubleshooting guide looks like it may lead me to an answer. I have to sort through it.
Interesting note- I just replaced my battery and when my old one was weak (low voltage) - the headlight would come up when the lights were on and stay down when the lights were turned off.
Interesting!
Thanks for the replies everybody.
Brian
Old May 13, 2009 | 08:35 PM
Brian's Avatar
Brian
Started working again on its own! Wonder what's up with that!
Old May 13, 2009 | 08:59 PM
Jet-Jock's Avatar
Jet-Jock
You sir have gremlins.
Old Mar 8, 2020 | 06:53 PM
Docwade's Avatar
Docwade
Sorry to resurrect a thread, but I had this issue and this videos squares it away:
To Left Headlight Stays up
