Bilsteins HD. I Did Wrong
Old May 5, 2009 | 05:22 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Alright, I feel like an idiot posting this but I heard somewhere the only stupid questions are the ones you don't ask so here it goes.
what is the broken/wrecked part of the shock? Is it the rubber thing on the shaft, the blue casing on the ground? Feel free to make fun of me but it is an honest question :o
Old May 5, 2009 | 06:24 PM
1SHADYZ's Avatar
1SHADYZ
WOW!! I made my order last night with the Sports
Old May 5, 2009 | 06:30 PM
hotwheels57's Avatar
hotwheels57
I believe BILSTEIN shocks can be rebuilt. If that's still the case, those could possibly be rebuilt to "Sport" specs...
Old May 5, 2009 | 08:42 PM
happa's Avatar
happa
its no stupid question, yes the rubber piece on the shaft was split and I had removed the blue casing. The shock could be pushed in by hand so it was shot as well.
Really?!? I wouldnt mind doing that to my fronts. Any info please!
Old May 6, 2009 | 08:30 AM
kendo347's Avatar
kendo347
I have bad news. The same exact bottoming out is going to happen with the sports. Maybe not as extreme as the hd's but the sports are still going to bottom out. Especially if you are lowered. I had to replace 3 of the 4 black bushings you have pictured. They are called a jounce bumper 2 rib 40m. Part # E4-B46-243 and are $3 each from the Bilstein warehouse in CA.
To get the shocks rebuilt you have to send them in and the cost is almost as much as it is to buy new ones.
Old May 6, 2009 | 08:38 AM
JEEP/C5's Avatar
JEEP/C5
The HD and Sports are the same length. So if you are lower than 1 inch from the factory specs then both shocks (HD and Sports) will bottom out large bumps. The sports are firmer so they may not bottom out as much but I suspect eventually they will look like your HD's over time. I have the HD's and I love them. My car is only lowered about 1/2 inch (maybe 3/4) so I have no problem with bottoming out. The HD are a great choice it really just depends on how low you want your car and what kind of driving you do.
Old May 6, 2009 | 03:55 PM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
I'm running the HD's lowered on stock bolts and so far haven't had a problem, now if I could get my Fat Daddy's to catch the pavement before the ACI spoiler I'd be a happy man................
Old May 6, 2009 | 04:16 PM
BUGZ's Avatar
BUGZ
Originally Posted by BigTattooMan
Wow, just remember every repair is a perfect excuse for an upgrade, at least thats what I tell the wife, "sorry honey their all out of stock parts I have to get this one"...
Old May 7, 2009 | 04:15 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Hmmm That's pretty much my plan, lowering the rears as far as possible on the stock bolts and then matching that drop to the front to maintain the stock rake.
I believe the OP said he used longer rear bolts which hopefully was the cause of him running out of travel...
Tim
Old May 7, 2009 | 08:15 AM
JEEP/C5's Avatar
JEEP/C5
Originally Posted by tstar
I believe the OP said he used longer rear bolts which hopefully was the caused of him running out of travel...
Tim
Tim, I would lower the front FIRST since I was only able to lower it about 1/2 inch on stock bolts without cutting the bushings (I have the z51 package so that may have made a difference). And then lower the back to match. After a week it will settle and I had to raise my rears some to get the rake right.
Old May 7, 2009 | 09:21 AM
IDM's Avatar
IDM
lowering your C5 to the extreme is really disastrous, I understand wanting to do it because a c5 with some nice larger wheels and slammed looks like a supercar. However, it ruins the underside, front end especially and ruins handling. Makes the car more so impractical. The back end is supposed to be able to sit down and have soft travel for traction. Any way Id go down all the way on stock bolts without cutting bushings and call it a day. At that level stock shocks are even fine, it looks nice...and when you are driving it, it looks slammed the way a slammed car looks when you are out of it photographing it (talking from experience with 2 c5s and many trials on each)
Old May 7, 2009 | 06:03 PM
tstar's Avatar
tstar
I thought the rear was the limiting factor, staying with the stock bolts. Well I'll find out one way or the other!
IDM thanx for the honest input spoken from experience. I plan on sticking with the stock bolts, hopefully the ride will be acceptable for me... if not, back up she goes!
Tim
Old May 7, 2009 | 07:53 PM
  #33
dobewillie's Avatar
dobewillie
that sucks but thanks for the post we learned a good lesson
Old May 8, 2009 | 12:19 AM
  #34
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Originally Posted by WKMCD
Thanks for sharing the info.
Old May 9, 2009 | 12:11 AM
  #35
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
[QUOTE=happa;1569975077]its no stupid question, yes the rubber piece on the shaft was split and I had removed the blue casing. The shock could be pushed in by hand so it was shot as well.
QUOTE]
thanks for the info!
