Fuel door won't open
Old May 6, 2009 | 01:16 PM
vet4me's Avatar
vet4me
Default Fuel door won't open
My fuel door won't open using the release button.I have to do it manually from inside the trunk.I checked the fuse,it's ok.I did have the battery disconnected recently for a Dyno.This is the first time I''ve tried opening it since last fall.can anyone give me some suggestions? thanks
Old May 6, 2009 | 01:26 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Did you ever have the center console removed? Off the top of my head, I can only suggest checking the wire connection underneath it that goes to the fuel button area. Maybe it has come loose, or was not re-attached?
Old May 6, 2009 | 01:36 PM
env00's Avatar
env00
Old May 6, 2009 | 02:09 PM
zr2lang's Avatar
zr2lang
is it making a poping noise that it is trying to release the door.My release mechanism was dry and had no lube.I used some white lithuim grease on the release mechanism and the hinge and haven' had a problem since.
Old May 6, 2009 | 03:23 PM
DeeGee's Avatar
DeeGee
I agree that you need to find out if its electrical or mechanical
Here's the troubleshooting guide:
Fuel Filler Door Release Inoperative
Step
Action
Yes
No
Schematic Reference: Body Rear End Schematics
1
Did you perform the Body Rear End Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Body Rear End
2
Operate the fuel tank filler door lock release switch.
Does the fuel door operate?
Go to Testing for Intermittent and Poor Connections in Wiring Systems
Go to Step 3
3
1. Disconnect the fuel tank filler door lock release switch.
2. Connect a test lamp between the battery positive voltage circuit of the fuel tank filler door lock release switch and a good ground.
Does the test lamp illuminate?
Go to Step 4
Go to Step 9
4
Connect a test lamp between the battery positive voltage circuit of the fuel tank filler door lock release switch and the control circuit of the fuel tank filler door lock actuator.
Go to Step 7
Go to Step 5
5
1. Connect the fuel tank filler door lock release switch.
2. Disconnect the fuel tank filler door lock actuator.
3. Connect a test lamp between the control circuit of the fuel tank filler door lock actuator and a good ground.
4. Operate the fuel tank filler door lock release switch.
Go to Step 6
Go to Step 10
6
1. Connect a test lamp between the control circuit of the fuel tank filler door lock actuator and the ground circuit of the fuel tank filler door lock actuator.
2. Operate the fuel tank filler door lock release switch.
Go to Step 8
Go to Step 11
7
Inspect for poor connections at the harness connector of the fuel tank filler door lock release switch. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 12
8
Inspect for poor connections at the harness connector of the fuel tank filler door lock release actuator. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
9
Repair the open or high resistance in the battery positive voltage circuit of the fuel tank filler door lock release switch. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 14
10
Repair the open or high resistance in the control circuit of the fuel tank filler door lock release actuator. Refer to Wiring Repairs in Wiring Systems.
Go to Step 14
11
Repair the open or high resistance in the ground circuit of the fuel tank filler door lock release actuator. Refer to Wiring Repairs in Wiring Systems.
Go to Step 14
12
Replace the fuel tank filler door lock release switch.
Did you complete the replacement?
Go to Step 14
13
Replace the fuel tank filler door lock release actuator. Refer to Fuel Filler Door Release Actuator Replacement .
Go to Step 14
14
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Document ID# 723456
Old May 6, 2009 | 04:50 PM
vet4me's Avatar
vet4me
Thanks for the info.I'll try it this weekend...
Old Jan 15, 2010 | 04:59 PM
Artem_Wolf's Avatar
Artem_Wolf
6th Gear
I have a similar problem. My fuel door opens, but only in 15 seconds after pressing the button. Besides, it is necessary to press once again the button to close fuel door.
Sorry, but I have Corvette recently. May be it is ok???
Help Please!!!
Old Jan 15, 2010 | 08:52 PM
AndyGra's Avatar
AndyGra
Navigator
Help Please!!!
If you have to hold down the fuel door release button for 15 seconds for it to activate, I would be looking for high-resistance corrosion. Somewhere. Do some continuity tests, some voltage-drop tests as the circuit is triggered. Or, run a new wire, bypassing the existing harness.
Old Jan 16, 2010 | 01:02 AM
It may be caused by corrosion in the actuator. I've got a write-up done by a forum member back in '08 on how to fix the actuator if that is the problem. If you'd like a copy, just PM me your e-mail address with Fuel Door Actuator in the subject line.
Old Jan 16, 2010 | 02:46 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
As for the OP problem. Happened to me the first day I bought my car!! And a couple times since, the connector comes loose.
Old Dec 21, 2011 | 12:36 AM
XPLOSYV's Avatar
XPLOSYV
This thread is what led me to this site! First night home with my C5 and I noticed it needed gas. I googled to find an answer and it had this at one the best
Old Dec 21, 2011 | 05:39 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
It's usually required for you to start a new thread about your specific problem when the thread you post in had been dead for so long.
Waking up an old thread will get the thread locked.
You need to descibe your problem a little bit more so we can help you, unless you have already found your answer.
Old Dec 21, 2011 | 02:47 PM
Joe Babe's Avatar
Joe Babe
There is a pull cable till you get to a dealer
Old Dec 22, 2011 | 12:42 AM
XPLOSYV's Avatar
XPLOSYV
Corvettezman, understood sir. Will do in the future. Just wanted to give the forum for helping me out. I was pretty much out of gas/luck until I found this thread. I had left the manual at home. So yes I found what I needed. Thanks Joe as well
To Fuel door won't open
