Switchbacks for clear corners
Old May 8, 2009 | 07:33 PM
jaxvet's Avatar
jaxvet
Default Switchbacks for clear corners
Just ordered a set of clear corner light assys, now where can I get the switchback bulbs for them?
Old May 8, 2009 | 07:36 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I have them in stock and ready to ship http://www.shop.jwmotoring.com/produ...&productId=139
Old May 8, 2009 | 07:53 PM
jaxvet's Avatar
jaxvet
I've never had to replace a bulb or had these assemblies out, are there two bulbs in each, what else do I need or will one of the stock bulbs be used in new clear corners?
Old May 8, 2009 | 07:55 PM
JW Motorsports
Banned Scam/Spammer
Those will replace the inner bulbs in the housings (2). You need a 194 size led for the outer sides(2). We have them in white if you want white.
http://www.shop.jwmotoring.com/produ...4&productId=20
On the LEDs if you want them add 1 to your cart. It comes with 2.
On the switchbacks add 2. They are sold as 1.
Old May 8, 2009 | 08:17 PM
Smokem02's Avatar
Smokem02
do you need the relay to slow the led flash as well or will they work with just the bulbs
Old May 8, 2009 | 08:20 PM
jaxvet's Avatar
jaxvet
Whats up with that too? Let us know cause I got the housings ordered. Thanks.
Old May 8, 2009 | 08:23 PM
JW Motorsports
Banned Scam/Spammer
When you add LEDs you will get hyper flash. I don't have the harness now, but I will soon.
Old May 8, 2009 | 08:47 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Did someone say Switchbacks?!
Here's a vid I made...
As far as hyperflash, some people like them.
If you don't, I got this harness from this site:
http://www.adaptiveperformance.com/hyper.htm
Old May 8, 2009 | 09:00 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
I have the 48 LED switchbacks in my clear corners. About as bright as my HID fogs. Can't miss me coming atcha!
As far as the 194's, check your state laws. They may be required to be amber. If not, get the white.
Old May 8, 2009 | 10:16 PM
jaxvet's Avatar
jaxvet
OK - I just placed my order with you for the 2 diff items.
Now, they are going to hyper flash, I guess that's a given. I haven't order one of those elinator modules yet, will hyper flash harm the cars elec system or is it just annoying to some people? I mean like over heating connections or frying anything. I know zip about electrics.
Old May 8, 2009 | 10:37 PM
NorCalVette Kid
St. Jude Donor '09
Old May 9, 2009 | 01:04 AM
Jistari's Avatar
Jistari
Well, it wont hurt anything ...kinda.
The low draw of the LED's makes the flasher unit think that the bulb is blown, hence the faster flast rate on the affected side. The faster flash shouldnt hurt the LED's but you will probably still have incandescent bulbs in the rear and theoreticaly they will live shorter lives due to the faster cycle time. But no, nothing except bulb life should be affected.
That bypass unit is a no brainer, takes literaly 10 min to install. Plugs into the harness under the dash (think its two screws you have to take out to drop the panel, just plugs in, no wire work needed) and once in, it bypasses the flasher unit that is in the hazard switch in the center of the dash (which btw is a royal pain to change if it goes). So I would think about getting the bypass.
Old May 9, 2009 | 08:35 AM
JW Motorsports
Banned Scam/Spammer
Old May 9, 2009 | 12:51 PM
jaxvet's Avatar
jaxvet
OK - thanks for the info - I'll get the harness as soon as I can
Old May 9, 2009 | 12:52 PM
JW Motorsports
Banned Scam/Spammer
Your lights were dropped off today BTW^^^
To Switchbacks for clear corners
