Engine Squeak
Old May 9, 2009 | 01:32 PM
dday14's Avatar
dday14
Cruising
Default Engine Squeak
For some reason my 01's engine will have an occasional squeak while its running. It only seems to do this about once a month or so but its very annoying specially considering the car. Is this an indication of something wearing out? A pully bearing or a harmonic balancer or something?
Old May 9, 2009 | 03:30 PM
GOZ2FST's Avatar
GOZ2FST
My '99 did that and it got worse and worse. Sounded like a bunch of crickets under the hood - people would stare.
I replace the harmonic balancer (didn't fix it), the serpentine belt (no joy) and the belt tensioner (bingo).
When it happens try getting a squirt bottle of water and squirt a little here and there until the sound disappears - that is a cheaper way to figure out where and what it is.
Good luck with this
Old May 9, 2009 | 03:52 PM
1sickz51vette's Avatar
1sickz51vette
yeah mine does it before the motor warms up, i sprayed some belt dressing on it and the thing squealed like a ****!
Old May 10, 2009 | 01:00 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I had the same result when I used belt dressing. It made the squeaking much worse. I used a bar of soap and the noise went away. Good luck!
Old May 10, 2009 | 07:31 AM
tdahl's Avatar
tdahl
water pump started to weep on my belt....... squeek squeek
Old May 10, 2009 | 11:55 AM
tirejoe's Avatar
tirejoe
6th Gear
Goodyear Gatorback belt got rid of my cheeps.
To Engine Squeak
